It was literally a 20 minute job :( It's been driving me bezerk!
I'm happy to not have you not pay me to not do it? Not? :D
If you want some tape I can probably hook you up. Either that or Con-Tact adhesive backed felt is good for this too.
only kidding mate. my car doesnt have many rattles.
if i hear anything i shouldnt, i just turn up the radio :D
hopefully got a buyer for my corolla so i dont have to sell my other cars due to the gfc!- quite happy as id sell my first born before i sold the stagea :D
anyone recommend a brissy local for a starter rebuild?
Edited by PetroDola
From what im told they cant be repaired as it is one of the copper coils that blows out (thats what happened to mine anyway) you will probably need to source a s/h one from a wreckers. I know they are the same as a VQ25, possibly VQ30. 3.5 has a different part number but may fit...
I have one here in need of repair if they happen to find the parts to fix yours...
3/4 of the way through fitting up my new motor with all my other bit's....hopefully tomorrow the motor and gearbox back in!
Nice intake mate... :D
You managed to keep the heat shield too. I bet its easier to work on the turbo out of the car...
sobering - i thought it mightve been an oil lubricated one and thats why it cooked.
sourcing one from wreckers isnt going to be easy around these parts , maybe down there, looks like my car is going to be bricking the driveway for weeks to come if thats the case.
what else other than an m35 has a vq25 though ?
thanks for the solid advice Scott
Edited by PetroDola
What bit can't be repaired? You have rewinders surely?
howd u do the diff ?
I got a bit carried away in the grass events at the local car show. I think I dumped the clutch too hard in reverse gear... :P
Gunna get it fixed in the new year. New diff, uni joint for the drive shafts, get the rear diff checked out, brass button clutch is a little noisy so that will get a look too.
I am keen to have an A1 drivetrain. Does anyone know if these cars will handle 8000RPM launches? :P
The J32 Maxima (2009) has a VQ25de I believe. Wouldn't think the starter would be any different to what we have.
Edited by iamhe77
I cleaned my Stagea last night! Filled it up with fuel. (full tank - $100 later FFS!)
Going to clean the interior and do a bit of a service soon!
She goes alright. Not as quick as a Turbo Datsun 1600 though :P But a hell of a lot quieter. :P
She goes alright. Not as quick as a Turbo Datsun 1600 though :P But a hell of a lot quieter. ;)
Pics?
nice man.
i'm still gonna call you Mr. Flinstone however!
intake looks nice. need to get Mr Fisher to make mine some time sooooooon.
+1, VQ25dd, but as we know, its FWD... so may fit, maybe not?
Do they have a relay or something that could be kaput?
soo...
finally got the car back in my hands today!!
alot of you know that ive smashed up my engine rather bad... that aside all is well now :blink:
done and spent a dime on it, but is very very good now!!
made 217.10 AWKW/250kw rears on the 21st run @ 16psi.... (poor car!!)
turbo pulls amazing... as per dyno graph :P
Edited by chef_stagea
not bad at all what turbs you running and computer
soo...
alot of you know that ive smashed up my engine rather bad... that aside all is well now :)
turbo pulls amazing... as per dyno graph :)
soo...
Good result and yeah, what turbo? (You need to get that 260RS out from under your name - its confusing!)
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
