lol the left side of the map is surge, the right side is when its running too hot.
That plot shows that if you are running 20psi, as long as its not hitting 20psi before 3000rpm and if you dont rev it over 8000rpm you will pretty much be making the most of the turbo.
Chances are that turbo wont be on 20psi by 3000 when using the right size exhaust housing, so its good!
They are not available from an australian distributor yet as garrett australia dont recieve them till January 2011 as far as my knowledge goes.
They are available from US dealers (ATP turbo and realstreetperformance are just 2 that we have found so far)
From this garrett link they keep using the figure 10%:
http://www.turbobygarrett.com/turbobygarre...bochargers.html
So I would say roughly 10% more than what they do now.
old 3076 is rated to 525hp atm, used to be 550hp from memory. new gtx3076 is rated at 640hp which is a 22% increase. seams a little optimistic to me using the same turbine housings but time will tell.
old gt3582 is rated to 600hp, new gtx3582 is rated to 750, 25% more.
Nothing to stop you ordering one from em now ;)
Especially with the dollar in good form
Nothing to stop you ordering one from em now :down:
Sure isnt! Ordering one a GTX3076 for my friends SR next week but ill be waiting till they are here in aus/wa when i buy my gtx35r ;)
Wow so considering i was planning on getting a 3076 and was gonna hit 20psi with 300kw's, so just a guess, but do u think the GTX3076 will be able to hit 350kw's by 20 psi?? Unopened RB25 Neo with supporting mods..
I'm also interested in knowing how GTX3076 performs on an unopened DET neo, but I'd 350kw by 20 psi is impossible without cams on ULP.
350rwkw is ~ 470whp, how much flywheel hp is it? Let's say 530fwhp. To make this power using PULP you have to force around 55lb/min of air down the engine's throat. 20 psi is 2.43 pressure ratio, plot this poing on the compressor map. I'd say compressor efficiency is still pretty good at ~70% at this point.
At 101% volumetric efficiency you will need ~7400 rpm to achieve this flow, at 95% VE it becomes 7800-7900 region, at 90% VE it's going to be 8300rpm.
So either make sure your VE is adequate at this point (cams, etc), or increase boost or rev engine harder. Or use different fuel, like E85.
And I guess for the new 76mm compressor with all that additional flow, .63 turbine housing will really struggle to flow enough exhaust gasses and will create some serious backpressure in the upper rev range. Looks like at least .82 A/R is an imperative from now on for GTX3076
Edited by Legionnaire
What would be the recommended configuration to get if i wanted to get an internal gate gtx3071, should i go 63, 82, or 1.06, and what dump pipe? Wanting maximum response and 250-275kw :(
If you go internal gate, as a minimum get the garrett IW .82 housing. Preferably see if GCG can supply you with a HKS IW .87
Do NOT go .63, the number of issues to name is annoying. Wont hold boost, problems with heat, choke your motor at any decent boost level bla bla bla.
Better yet would be external gate, but everyone has their price.
GL
Wow they are huge increases!
It's going to be interesting to see how these things match up to "typical" installs using the old-spec GT series turbos.
With the increased compressor flow comes the need for increased turbine flow and maybe a touch less low end response. I'm left thinking the bigger 1.06 housings will become more of a common selection depending on engine and turbo combination.
Just taking time to digest it all.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
