My brother just got his car back with a gtx3076. Made an impressive 261rwkw on 14psi. Rb25 neo
This is just a base tune and is being tuned on LPG + 18-19psi. Should see over 300rwkw easy
Whats it like response wise compared to the gt3076?
what fuel system is he rnnig for a 300rwkw LPG setup?
12 injectors?
12 injectors?
It's the vapour injection system with just 6 injectors. But LPG injected are apparently pretty large and should be able to handle it (hopefully). I'll post up when it's done. Should he Friday
I was excited till I saw it was a dynojet dyno...
Realistic figure would be 10%ish less so 550ish, still impressive!
Wasn't your 410kw on a hub dyno? I could be wrong, but I had that in my head. I've never seen >600whp on a Dynojet from anything smaller than a GT3582R before.
You are correct, but I know it was inflated :) Hense why it only makes 360rwkw on a roller haha
There is no authority on whats high or not ;)
But yeah, DD seem to on average read a little lower than a Dynapack - so its fair to say its a solid 15-20% more power than yours... so its fair to say its a turbo which is theoretically capable of full boost by around 4000rpm on an RB25 and make near 420wkw on E85 on a Dyno Dynamics dyno?
This was with a .63a/r hotside, too....
  • 4 weeks later...
Finally I got word the GTX3071 has arrived and will ship after Easter, They were going to send the Tial .82 with it but that is now out of stock even though I ordered it 2 months ago, not happy. It seems the only Tial housing they have left is the 1.06, is that going to cause me too much lag for a 2.5? I have a VQ35 im building up which would love the extra AR so im not too worried, just wondering if it will work well on the 2.5 for now or if its overkill?
with the torque converter your running Id imagine it will feel flat and lifeless down low and nothings gunna happen at all till you hit 4k, then all hell will break loose to the limiter and beyond :laugh:
I think 1.06 is too big for a 2.5L
I agree, the 4k stall will help. I will try it out, hopefully the flanges are the same and I can just order the .82 later, when it comes back in stock.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
