Very very nice boost/power curve, its on the verge of the magic 200kw by 4000rpm mark despite being not overly aggressive on boost :) Very much looking forward to seeing what ethanol does to the party!
The torque is ALWAYS going to drop off, unless the engine isn't being revved high enough :)
mine doesnt drop off much, i see alot of the hi flows have quick up down torque curves too,
Edited by SliverS2
Well it failed... looks like its to rich on cruise & decelatration...
Next EPA test is booked for 23Rd July..
oh well..
Hmmmm how does it work? Do they record it or you can keep going back again and again until it passes?
yeah you can go back as many time as you need.
the guy there was very helpful, they give you the print out of the test showing the nox,co,co2,thc levels so you know where the car is failing and where to change the tune
the guy was so helpfull there he marked on the graph where it was failing for the tuner to see and adjust to suit.
they even know i have an adjustable computer...
Ahhh good stuff, keep the updates coming :yes:
Is it an expensive exercise? And you can book in voluntarily? (If there is a webiste or something can you point me to it?)
the only extra costs would be making up an exhaust with 1 or 2 cats, a couple of hours on a dyno, and just go for it..
yeah its best to do it voluntarily they will see that and help you out.
just call RMS / EPA 137 247 and follow the instructions
the EPA test is for free also.
Yep, split .82 GT3076. 6 Boost, twin 40mm turbosmarts plumbed back into the 4.5 inch 100cpsi cat.
Here's hoping you crack 350 Owen. :)
:yes:
The way it makes the power will be awesome too!
It all had to be assembled on the bench and lifted into place. The front gate can't be unbolted with the turbo in the car and there is one turbo bolt that is almost impossible to get to. Other than that there is plenty of room. :)
It sounds like such a nice setup, how hard/labor intensive was it to plumb back the gates and make the front pipe?
Not that hard, there were two flex joins to fit before the cat/merge but it was getting the wastegate outlet merge right that took the time. I also got the 3.5 inch exhaust pipe tucked right up giving good clearance from the road, well over legal height at the moment.
I was happy with how it turned out, and the noise level with only a Hooker was very reasonable considering the size. (I was so impressed I fitted a hooker 3.5 inch to my car today.)
looks nice!
Is the rear housing from atp turbo?
The Vband was welded on to the housing, I haven't seen one like it before. I guess this one is equivalent to a .63 in response but with better top end.
The twin scroll is definently appealing due to the response it gives, but the tight fit/complexity of the dual wastegate plumbacks is slightly off putting and probably expensive to get made.
Top end wise it doesnt look too different to most gt3076r turbos with that boost, but i think the mid range would probably be better on the twin scroll setup
When is your setup getting on full boost 34geeteetee ?
Edited by Mitcho_7
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
