New tune today for the GTX3076, I have gone crazy with spring pressure running the maximum 26psi the 45mm turbosmart can take. It held boost well at 24-25 psi with no controller, and power came on smooth which should be good for grip.
I'm booked in for the Sandown trackday next Saturday so it was a conservative tune, not sure I need to crank it up at the moment anyway. ;)
looks a bit lazy.. :ph34r:
So the GTX35 Twin scroll set up went very well.. We ended up tunning it late last night as my tuner is going away, didnt touch cam gears at all.. and spent only 2 and abit hours on the dyno..
18PSI by 4000RPM, 424kw @ 20psi @7900RPM it just keeps making power up top tuner wants to clean up some fuel pump wiring before we do anything more.
dyno graph will be up when my tuners back from holidays and some more tuning & boost
Big thanks To GregR31 who built the motor & Chea at powertune these guys have been very helpful!
Edited by BMYHOE
hey guys after reading this thread i have become increadibly confused! aha
at the moment im in the process of getting a new turbo was going to go a GTX 3076 .82ar but after reading all thing not im not so sure!
i have 6boost mani, tial 44 waste gate, tomei poncams with exhaust gear and kept VVT, supporting fuel and ignition, power FC and greddy plenum
im hoping for around 400-500hp on around 20psi running on 98.with water meth injection.
what turbo would use recommend and wat spool rpms am i looking atm?
will be used for drift so im after a bit of responce with MINIMUM 400hp more some id be so happy with 450
My GTX3076 would be right at home on a drift track, over 4000rpm is drifting territory, i light them up like a V8, on a straight road in second and also in third at times, so if your going round a corner then it will be too easy..
I dont know if you need the exhaust gear, theres plenty up top without one..and the meth probably not as good as the ethanol i use.
this whole time ive been driving around boost has only been on 15psi - 352Kw LOL i thought i was driving around on 20psi 424Kw LOL
this thing is animal very happy with the set up
Edited by BMYHOE
although id love to use ethanol, its not an option at the moment. obviously chasing some good torque for drift especially trying to fry 255s in 3rd! and still very much want that agressive snappy power, would you suggest the gtx over the gt?
If you want snappy go the GTX3071 with either .82 or if you don't mind a lower top end output but want more midrange and response, the .63.
My GTX3076 isn't as snappy as my old gtx3071 was.
hmm.. just wanting to be able to easily slide around in 3rd and hav it hit like a freight train haha
I dont have experience with many turbos, but judging by the dyno graphs the gtx's really need ethanol and boost to worthwhile
id just copying mafia's build, with the gt3076 0.63 ( external better) and some water meth or ethanol.
Edited by SliverS2
If you're looking for a good turbo setup I think Dale_Fz1 has one for sale. Its a Garrett GT3076 with a HKS 0.82 rear housing. I think he's selling it with a ported standard manifold, dump pipe and intake pipe. Has about 4,000kms on it.
I know for a fact that his setup made 300rwkw easily on 18psi.
Maybe sell the HKS rear housing (would sell very easily) and get a 0.63 rear.
cheers for the feed back guys,
problem is i already have a 6boost external single scroll mani, running a tial 44. i have no chance of getting e85 at anystage in there near future :( ,i will be running possibly water meth at a later date so im thinking a standard GT3076.82 on 18-20psi and im hoping this should give me what im after??? then if i get the water meth it can only advance on this. also only wanting to buy brand new. just worried shes gonna run out of puff up top, i guess its not the hp im chasing although 400minimum, its the BIG NM i need to fry the tyres in 3rd... f**k so confusing now.
the tune shops r recommending the GTX35r or GTX3076 .82ar but are saying at 20psi the gtx30 will struggle to come on hard and make the power/nm im after :/
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
