The little quips are already classic- Like when he said "The only way that radio message could've been any scarier is if it was delivered in the dark"
That was pure gold!
DC is great and they should have used him like this last year.
Any news on the magic Ferrari DRS?
http://www.youtube.com/watch?v=f1k-nCXW87g
"Alonso was the subject of an odd situation in China when his rear wing opened outside of the designated DRS zone. Following Michael Schumacher, Alonso's wing activated between turns 14 and 16, despite the zone being marked out as a section of the straight before turn 14. The reason was an error that caused the system to offset by 450 metres, costing Alonso time. He will not be punished, but the FIA are looking in to the cause of the incident."
Mark has written an article confirming my feelings after China.
"But we're still learning and we saw in China that qualifying position might now be less important than in the past.
We only have six sets of dry tyres for qualifying and the race (three sets of prime, three sets of option) and while you don't want to be qualifying 18th every weekend, you're better off saving a fresh set of tyres for the race rather than doing another run in Q3 to gain one grid position.
My fastest lap in the race was 1.4sec faster than anyone else's. That was due to my having more new sets of option tyres in the race. It's given us plenty to think about."
So I can see Q3 will now be a 1 lap wonder only and EVERYONE will have the 1 virgin set of tyres for the race. So that will pretty much cancel everyones performance out - although there might still be some who run with the faster tyre at the start, some in the middle and some at the end.
Especially seeing as Vettel doesn't know how to pass a car without running in to it
I was praying so hard that they'd collide I was almost ready to resort to voodoo sacrifice. Vettel and Hamilton DNF = Webber win. How awesome would that have been!
They don't need it to happen/fail again and open in say, Eo'Rouge (sp?)..... could lead to a monumental accident.
Eau Rouge FYI.
That was always my first concern when I heard about the moveable rear wing. We've had FIXED rear wings fail before (remember Raikkonen?), and adding moveable parts into the equation can't help the chances of a wing failure.
Mind you, IMO if you're going to have it at all, it should be at the driver's discretion. I hate this idea that it can only be used in a certain section of the track.
We only have six sets of dry tyres for qualifying and the race (three sets of prime, three sets of option) and while you don't want to be qualifying 18th every weekend, you're better off saving a fresh set of tyres for the race rather than doing another run in Q3 to gain one grid position."
as much as I don't like him, Hamilton worked that out before China. And he won because of it.
^^ fkn This!! ^^
only because of the massive advantage of green softs. not because he got an injection of awesome in the first pit stop. Before that he couldn't even pass the back markers... I think he made 2 positions in 17 laps or something before pitting??
As a McLaren fanboy, I'll have to go for the 'Not very' option thanks Eddie.
On hard tyres & no KERS vs all cars around him on the grid with soft tyres & KERS.
is anyone else wishing they didnt have to wait so long between races lol. i need more f1.... what other series is as interesting?
Yes!
I watched the first race of the btcc online today. Love the brands hatch circuit, I don't think I knew enough about the series, teams and drivers to really get into it...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
