here's one of many sources, a 1991 interview with Senna:
http://www.grandprix.com/ft/ft00090.html
it was partly a 'square up' for the previous year and partly a petulant sook at having to start from the dirty side of the track. either way its a premeditated decision to take another driver out if they get in front. What a champion.
So that's how he secured one championship, another he won with less points than Prost because they only counted the best 11 (from 16) results back then! WTF? And the 3rd all his rivals had at least 5 retirements and he only suffered 1.
This guys alright... :thumbsup:
Good to see I am not alone with regards to ill feelings towards Senna. No doubted a talented guy, but there were plenty of times when others had his measure, including his team mate. Harry touched on it...there were occassions when Senna only beat Prost because Senna put him to the sword and Prost preferred not to crash with his teammate for the sake of the team and results. If Prost was as single minded the two would have wiped corners off each others cars far more often.
I only really remember watching GPs from 1988, with clear memory from about 92 onwards...didnt know enough about what I was watching to actually rate Senna, but I never liked him at the time.
Ironic thing is Ralf's quite a successful DTM racer. Shows the gulf in the comparative skill level required for competitiveness in F1 and a prod-car derived racing category, I guess.
Perhaps the Toyota was never a world beater but given the alleged money thrown at F1 it seems like they needed to hire a serious top tier driver or someone on the way up like Kubica to wring the neck of it.
This elitist is flying Tiger Airways to Qld in a week or two on a $30 special so I would say I either like taking risks or I am a cheapskate....I sure hope they serve a precocious chardonnay onboard with the canapes.
hahaha nice knowing you on that tiger!!
"Q: Rooftop swimming pool, bowling alley, revolving sushi bar - just some of the features most F1 motorhomes don’t possess. If you could add one thing to your team’s motorhome, what would it be?
SV: A good gym with a sauna. My Finnish trainer would be very happy then. And you wouldn’t struggle to find all the other Finnish guys in the paddock. Just go to where the sauna is!"
so vettel wants to find finnish boys eh? at least it's now clear where his sexual preferences lie. not that there was ever much doubt....
Less than 2hrs until P1, who will end up on top?
Looks like it will be wet and cold.
Edit - Lol at Seb V wanting the penis.
Glad I'm not the only one looking forward to it. Not sure why though, some numbers showing up on my phone which will not necessarily have anything to do with qualifying or race pace.
Ferrari updates could be interesting though :D
Sutil seems keen for a wet one....
Q: It is always said you are a wet weather specialist. Are you enjoying the weather forecast for his race?
AS: Yeah, yeah, it looks very rainy, so I enjoy it absolutely. We have not had a rain race or race session this year. Different story with the Pirelli tyres, we have not so much data in the rain conditions with these tyres, so it is going to be a challenge. But in general I like the conditions and I think we are going to be good.
I saw an interesting thing today. ferrari's F1 budget is still near $400mil. old redbull is 4th highest with only 204mil behind Ferrari, Mclaren and Mercedes. they are sure getting value for money these days.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
