or maybe you just refuse to concede he may have a legitimate point?, Troy.
I was rooting for the guy, preying he was going to get Vettel. The traffic for him was no different to what it was for Vettel, there was actually one moment with a car where Vettel got badly baulked and Hamo was right on him....he is having a sook because his nature is to be a whiney bitch. In the heat of battle it appears to surface when he gets a sniff....all this talk that he is the only one able to take it to Vettel....i like myguys to have a little humility. He slags off the team sayign the car is no match for RBR, yet he has won a GP and has better race pace at the last round...yet still sooks the car isnt quick, the other competitors are against him because he isnt German or the sponsors of teams.
GIVE IT A BREAK HOMO! I was just about converted...but now I am going to have to go back for rooting for Button to t-bone you :)
it's not like He was racing them for position stooge.
the back-markers having their arses lapped are supposed to get out of the way sharpish when flagged
The first driver on the scene loses a few tenths when they come up on backmarkers too so it usually evens out over a few laps but you are spot on, they need to move the hell out of the way.
Fisichella was pretty ordinary when it came to being lapped.
<snip>
<snip>
He was the hackiest hack that ever hacked
Im so happy he moved to the fuzz. Its nice of them both to contain as much hack as they can in the one spot for me to dislike
but anywayzzz, Saturday's retarded ignition battle looks like it should be the best one yet!
Edited by ctjet
Why the phark does anyone expect an F1 driver to be humble? I mean really. How is that in any way compatible with having the kind of self belief to know that of the billions of people on the planet they are, in fact, the fastest of all of them. Humble be fkd. It doesnt work that way.
Oh and for all you whinging about Hamo whinging you should have been around when Nigel Mansell was driving. If they gave out trophies for bitching he would have a shed full.
agreed troy. homotin is a whiney little girl. even worse he's teachers pet. he loves latching on to the stewards arses and sucking hard has he can...
"I just hope that the stewards are wary of it, and I'm sure they'll do a great job of it."
oh pah-lease. like he's pleading whiney radio calls on his team radio "chaaaaarlie, can you do something please" such a whinger.
I don't remember him ever being anything OTHER than a cockhead. he can steer ok but his idea of his talent doesn't really match the reality. he has walked into a car that since his very first steer of it has been in the top 3 cars on the grid in every year he's raced it. he should have had 3 WDC or more by now.
fkn fanboy
Friday is apparently a Public holiday during the GP in Monaco and all the shops are open to go and see how farken expensive shit is there. Thats the reason I heard for the Thursday practice.
its the annual wheel and deal day
but what a day!!
Definately going back, the place is unbelieveable
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
