or maybe you just refuse to concede he may have a legitimate point?, Troy.
I was rooting for the guy, preying he was going to get Vettel. The traffic for him was no different to what it was for Vettel, there was actually one moment with a car where Vettel got badly baulked and Hamo was right on him....he is having a sook because his nature is to be a whiney bitch. In the heat of battle it appears to surface when he gets a sniff....all this talk that he is the only one able to take it to Vettel....i like myguys to have a little humility. He slags off the team sayign the car is no match for RBR, yet he has won a GP and has better race pace at the last round...yet still sooks the car isnt quick, the other competitors are against him because he isnt German or the sponsors of teams.
GIVE IT A BREAK HOMO! I was just about converted...but now I am going to have to go back for rooting for Button to t-bone you :)
it's not like He was racing them for position stooge.
the back-markers having their arses lapped are supposed to get out of the way sharpish when flagged
The first driver on the scene loses a few tenths when they come up on backmarkers too so it usually evens out over a few laps but you are spot on, they need to move the hell out of the way.
Fisichella was pretty ordinary when it came to being lapped.
<snip>
<snip>
He was the hackiest hack that ever hacked
Im so happy he moved to the fuzz. Its nice of them both to contain as much hack as they can in the one spot for me to dislike
but anywayzzz, Saturday's retarded ignition battle looks like it should be the best one yet!
Edited by ctjet
Why the phark does anyone expect an F1 driver to be humble? I mean really. How is that in any way compatible with having the kind of self belief to know that of the billions of people on the planet they are, in fact, the fastest of all of them. Humble be fkd. It doesnt work that way.
Oh and for all you whinging about Hamo whinging you should have been around when Nigel Mansell was driving. If they gave out trophies for bitching he would have a shed full.
agreed troy. homotin is a whiney little girl. even worse he's teachers pet. he loves latching on to the stewards arses and sucking hard has he can...
"I just hope that the stewards are wary of it, and I'm sure they'll do a great job of it."
oh pah-lease. like he's pleading whiney radio calls on his team radio "chaaaaarlie, can you do something please" such a whinger.
I don't remember him ever being anything OTHER than a cockhead. he can steer ok but his idea of his talent doesn't really match the reality. he has walked into a car that since his very first steer of it has been in the top 3 cars on the grid in every year he's raced it. he should have had 3 WDC or more by now.
fkn fanboy
Friday is apparently a Public holiday during the GP in Monaco and all the shops are open to go and see how farken expensive shit is there. Thats the reason I heard for the Thursday practice.
its the annual wheel and deal day
but what a day!!
Definately going back, the place is unbelieveable
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
