My first impression,
you didnt give me a opinion in the first place..
instead i got sh*t for you.
and what you said has no relation what so ever about this topic..
Is what you do, going around telling people they dont deserve there car..
If I told you dont deserve your car
what would you think?
  • Replies 61
Can't you go a day or two without thrashing the car?
HURRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
DURRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
hahaha...lol...
of course..I hardly drive it in the first place..
maybe once a week..not even...
and when i drive it..dont even hit full boost most of the time..
just cruz really...
Ive done the mods almost a month ago...ill be lucky if i even done 200km..on it...
LOL!
"I'm not sure if I can drive the car hard after doing mods and not checking it on a dyno with a new tune so I'll ask online and see....and drive it hard in the meantime"
Great thread, would read again
No you didn't, stop trying to claim you are a super mechanic, if you were, you would know the basics of engine tuning.
On topic, screw what everyone else says, it's actually fine to drive your GTR in that state. There's dial switch underneath the car (directly under the driver's seat) that adjusts fuel and power. Give that a turn until you find the car makes more power, then lock it.
No tuners, no ECU no worries :bunny:
wat?
So seriously, wat?
I say rock out with ya cock out. it's your car bro enjoy it however you want. hop in that mofo dial up 8,000rpm and smoke those haters next to you.
ppl alwayz be hating just cuz yo got the ballz to try some sh1t and got a hot car, they prob cruzn in some sht box. it will be cool. just don't wind the boost up past 22psi or so cuz thoze turbos wont make much more then that.
hahaha...lol...
just cruz really...
LOL. 'You' did these mods but don't know about ECU's and tunes?
Troll. :bunny:
Thanks lookingforboost and beer baron for your support...
Of course i knew about ecu its getting done soon..
Ive got the ecu...my tuner it just busy thats all...just the time in between thats..
Well I found out it is safe drive the car from other mechanics and tuners.
because it still runs on standard ecu and boost..
just as long as you dont rev it to redline or on boost all the time which doesnt come on until 4.5 - 5rpm anyway....or give it in top end...
it doesnt matter if i have bigger injectors or hi pressure fuel reg and fuel pump...
The car will still run the same as standard because its still running the standard ecu
so the fuel mixture will still be the same...I know i its putting more volume of air but
just as long as you dont drive it like you stole it it will be fine...
It will not run rich or lean. The only way it will run rich or lean is that if i have a faulty airflow meter or a oxygen sensor..
Fuel pressure does not matter, the pressure that does not get used or fuel will go back to the fuel tank as it normally does...
Ah sorry but no.
The car will not run as factory at all with larger turbos, injectors and so on that flow more than factory.
The ECU has not allowed for it, because it cannot know. As Trent said, you'll be lucky if there is no damage done from how rich it would have been running.
Fuel pressure does matter as well.
I think you need to get an understanding of how things work.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
