So today I parked the stagea on a gradient sloping to the left. I had about 1/4 tank of fuel left, and did notice that the gauge went right down to empty on the slope. No biggie, I thought to myself.
Well when I went to start the car again, it wouldnt start. It cranked but only the odd cylinder fired.
I had to roll the car in neutral onto flat ground before it would fire.
Normal? Just a quirk of the car?
https://www.sau.com.au/forums/topic/345735-dont-park-on-a-slope/
Sadly....I to have had this problem...Lol...was more of a slope to the left though
Had to get me some fuel...Started then cut out....had to get him to push me backwards till i was on a diff angle so the fuel pump was covered again :/
Im getting the exact same problem on my driveway with a full tank of juice.. and sporadic.. took it for a two hour drive thursday night .. come home park on the drive , after refueling to a full tank... refuses to start. heaps of battery. Then i leave it for an hour play with the shifter .. finally starts in nuetral... Then starts again in park.
Then the following day.. refuses to start again.. full battery power lights are beaming.. im thinking shift lock or starter motor.. anyone else got any ideas?
did however notice it made a few slow spins of the starter when it did start like a dying battery or dying starter motor.. then the following day made clicks. now does nothing.
yeah shes a 2T brick where she sits.. need it towed ..starter motor is screwed.
Edited by PetroDola
It happened to me a lot. I either dont let it go below a quarter full or turn the car so its nose down!!! Took me three goes at running out of fuel before I got the hint that I really need to watch the tank though...
are you kidding? this happening on m35 too? God they fixed this sh!t on most cars in the 80s!
Not sure about the issues with starting it on the slope, but our fuel gauge can definitely respond poorly. I parked on the road outside my house last night for a few hours, trades people were on the drive way when I got home, when I went to move the car later that night the gauge had mysteriously dropped 25%.
no it was pure coincidence which happened to be on the steep drive..later realising my starter motor died .. didnt realise that nissan starters have a tendancy to just work then not work .. with no warning.. unlike other cars that generally give you slow turnover symptom similar to a battery dying.
Edited by PetroDola
I don't know if it would help, but I think if I had these issues when the tank got low I think I would check my cradle; see that it hadn't moved from where it's supposed to be, that the pump was mounted properly, check the actual level in the tank. 'Cause even when the level is really low, the cradle generally keeps enough around the pump to keep it submersed. And I know that even when you get the cradle out of the car, it's actually pretty difficult to empty that fuel OUT. So it should still be seeing some fuel...?
yep happened to me after work, just worked an 11 hour shift and that was the last thing i needed. The pick up must be on the drivers side cause my car was sloping toward the gutter and i had a quarter of a tank. It started but it soon died before i could take off. Pain in the arse
  • 4 weeks later...
slightly off the topic but to do with fuel gage part.
I notices that when I thrash it for a good ten minutes or so my fuel take gage drops about 20%. then as I go back to normal it slowly comes back up. could this be something to do with the G-force?(Even though there wouldnt be much at all with my fridge)
Can't confirm, but been told the V35/M35 fuel gauge acts as a fuel consumption gauge too, so if you thrash it it'll say you have less but if you drive conservatively it'll give you more.
But this could be 100% wrong, just what I heard through a random stagea/nissan convo.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
