because? too fast for no cage?
Told me not to bother coming back unless I have fulfilled the regulations for a 10.99 or faster.
ANDRA are a dinosaur organisation and a laughing stock in my opinion, but that's a whole other thread haha
I wasn't racing, I was just trying to run a time... I actually was waiting for the other car but as you can see they waited ages as well haha
Haha true - thats a very impressive time off a 1.9s 60ft, mid 10s car on a good run, for sure :worship:
Great work Simon :cheers: ,
did see you parked on Friday night :/ ,
Great to see her run so well Wed ,
when will Drags get it & just let guys run regardless of time :spank: ,
pay & get kicked out :unsure:
Keep up good work :thanks:
Congrats man, that seems to be the best bang-for-buck RB25DET turbo I have come across, are there options to fit this to the stock manifold without external gate, or are they too big and needs to be highmounted??
I dont wana change my manifold and add an external gate so just lookin for a good turbo like this which will give me 280-300rwkw on a RB25NEO..
Or should I just f**K off and get the hypergear atr43?? Any ideas fellows??
cheers
i can't say much about the atr43 , from what i've read there's heaps of variants . the person to ask would be STATUS , he may be nice enough to pm you a dyno sheet of each on cars with similar mods? for $8-900 i don't think you can purchase a hypergear of similar size for that?
Has anyone tried the td06 l2 10cm on a rb20??? i'm hanging out to see whether the 10cm is too laggy?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
