What flange is on your greddy manifold? If its T4 then no.
T3 or 3 bolt then yes.
T67 10cm would be nice on the 2.8, be sure of how much power ur chasing then pick the turbo to suit. Dont concern yourself with picking one to suit your manifold, it doesnt work like that.
+1 a T67 on a 2.8 would be sweet! I would copy SimonR32's setup as much as possible with the 6boost manifold and the Tial MVR 44mm wastegate. Same power with more response would be spaz!
I'm looking for a replacement for my S2 RB25, I've read through this thread but couldnt find a concrete answer, the range of Kandos seems to be a bit tricky. Would something like this (TD06SL2-20g) http://www.ebay.com.au/itm/Kinugawa-Turbocharger-RB20DET-RB25DET-2-4-Cover-8cm-T3-V-Band-TD06SL2-20G-/290649134040?pt=AU_Car_Parts_Accessories&hash=item43ac09d3d8#ht_2643wt_922 be ok for a mild setup on my 25? I want an internal gate that will fit on the standard exhaust manifold. Looking for around 250-270rwkw. Would it be alright or am I way off?
I've got a FMIC and exhaust currently but I've got a z32 AFM, injectors, PFC and upgraded in tank pump waiting to be fitted.
Yeah how so? Are they struggling at higher boost levels? I'd be interested to find out. I really want to keep the engine bay looking standard. Id be prepared to sacrifice a little bit of power if it meant keeping an internal gate turbo on the stock manifold. But then again if it's going to be really shit I could just get an external gated one and just try to make it look neat.
Is there anything wrong with the 3" anti surge inlet covers?
Reason I ask is I'm look at getting Eiji to make me a TD05-18G with 10cm (its for an rb20) exhaust housing. And the options are either 2.4" normal cover or the 3" anti-surge. Any negatives for the anti-surge cover or reason to avoid? It'll be internally gated as well against the advice of everyone here.
Interested to see how you go with the TD05-18G. I finally scored an 8cm Trust TD05 housing so will grab a Kando TD05 core with 3" Compressor cover. Will throw it on my external gate / 6boost setup whilst my TD06-20G is being rebuilt. Will be interested to see how the setups measure up.
I need to order either of these by the end of the week. Thoughts? Going on an internally std RB20 with 6boost, Turbsomart 45mm gate, Plazmaman plenum and an 8cm housing.
Anti-Surge Cover
Or
3" Cover
The anti-surge compressor turbo has a slightly different turbine. 11 blade Inconel Wheel
The plain 3" cover is dimensionally similar but 12 blade. I think I will go the 12 blade plain comp cover unless some turbo guru tells me otherwise. Is the 11 blade wheel the TD05 version of the L2 TD06 wheel?
Ur brave to go internally gated dude, despite what everyone says- hope it works for u, if it does pple will follow suit, including myself!
Same same, I wana keep it internal too, but i think u can keep the stock manifold if u dont go bigger than TD06SL2-20G 10cm housing.. Which is kinda where im headed, till someone proves that the internal gate works too.. Dont know what the prob is, moreso issues with holding boost n boost creep as u say
If you guys have to have an internally gated turbo then why not go with a proven hypergear??
Exactly.
I really don't understand why people are fussing around with the internally gated Kando turbos when their results aren't great compared to the Hypergears which are working really well IG.
After reading both threads the Kandos SEEM to produce more brutal neck snapping acceleration factor on the street, less issues getting there and seem to love boost and have lot more potential in them, maybe this also has to do with the setups being external gated.. AND theyre half the price of HG turbos (kinda adds up to same with ext gate, custom dump, plumbing etc), but then later down the track u canalways swap a newer better kando turbo cos its cheap!
The internally gated TD05-18G 10cm is also available in a Trust kit. Having been passenger in an R32 GTST with one of these and comparing it to my TD06 they are more than enough for the street and deliver a noticeably smoother delivery. But on a 20 still fairly lethal enough to put a smile on your face. The TD05/TD06 really comes alive at 1.2-1.4 bar so screw the boost in I say.
TLDR; nothing wrong with the internally gated TD05-18G 10cm. TD06-20G, id be looking at least at a 45mm external gate (going off the trust kit;s specs)
wtf?????
Go check out the kando thread on Nissansilvia, few guys have tried the internal stuff with very average results...
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
