Received my turbo today, Dam it's a small thing. how do i measure this turbo to see if its actually a 10cm housing and not a 8cm.
The t3 flange has casting imperfections on them and looks shonky. ARTZ housing looks way better condition than mine.
Would it cause any issues and should I say something to Eiji?
looks pretty dodge.
ARTZ housing;
I wouldn't worry about that "imperfection" too much... It's not going to make any difference, but if you are worried just rub it down a little with a small file.
The housings also look tiny compared with a Garrett, it's just because they are skinny
Edited by SimonR32
  On 09/01/2012 at 9:32 AM, dori34 said:
ordered boxing day, arrived today.
minus the pub holidays so not too bad.
thanks for the tip Simon!
tune eta, 1st wk of Feb!
so ~14 days
  On 09/01/2012 at 9:51 AM, chris_82 said:
Do u think a TD06 20g internal gate kando would be too big for a 2L 4cyl engine, lag monster ?
nope , sr boys seem to love them :)
Speaking of build quality, I thought I would post some pictures of my turbo because I have just pulled the front cover off!
This is after half a dozen track days, 3 times on the dyno, a trip to the drags, powercruise, a few motorkhanas and about a year of light driving :)
Front Cover Outside
Front Cover Inside
Compressor Wheel
Reason why the front cover is off (Welding on an elbow)
apparently the TD06 wheels dont work too well in the internal gate housings.
Ive done a td05h-18g on an SR20DE, tuned by Jez, is very impressive yet Im not confident the internal gate TD06 variant would be the same
best thing to do would be to get a china spec trust 3 bolt manifold, then get the 8cm trust 3 bolt rear housing and a decent gate. you would be laughing then :thumbsup:
Whats the difference between the TD05 and TD06? I wouldnt think there is enough wheel difference to make a difference. Is it because the TD05-18G you used was the T518Z rip off so has a different design housing?
Well I just ordered my TD05H-18G. Be interesting to see if backed to back with the TD06-20G. I am hoping I still make 250rwkws and hopefully make at least 25rwkws more at 4,500rpm.
  On 10/01/2012 at 7:37 AM, Roy said:
I just ordered my TD05H-18G. I am hoping I still make 250rwkws and hopefully make at least 25rwkws more at 4,500rpm.
Isn't that a fairly small setup? Found a Kinugawa chart indicating they are good for ~250 crank kW at max.
  On 10/01/2012 at 6:01 AM, pipster11 said:
Hmmm, maybe a t67 would go well on my 31
Or myabe its a bit too ambitious for a stock bottom end rb30e
Thoughts ?
Sounds pretty normal to me, just stick a small cam in it aswell, (something around 220@.50) and some springs ,and you will make good power ,most people stick 3540's .82 on them at least...
If you don't do cam, it probally won't make more than 240-250rwkw, thats about all you will ever get with stock camshaft, regardless of turbo...
I'd try a TD06H 25G 12cm personally, with a auto it would run 10's on a good condition stock bottom end i would have thought...
cheers
darren
Edited by jet_r31
