lol i wanna make that track day before the rego expires dude, i need to be able to fill it up wherever and whenever, jerrys just dont cut it!
Im seriously struggling to find elbows for the T28 at a decent price... might just get the .64 housing for the disco afterall (its cheaper in the short term)
  On 09/02/2012 at 5:22 AM, dori34 said:
AWESOME!!!
jez, remember to do a dyno run with and without VCT please if u get the chance :)
i want to see if it really does make a difference.
alot if run up on the dyno properley... spent hours with cam gears on numerous occasions trying to fill the void from no VCT.
cheers for clearing that up Trent! would you have any idea why theres a tapping noise when VCT is engaged? my tuner rekons its slightly touching the piston?
jez how did it go last night?
Roy: the billet wheel looks interseting,
how much did your one set you back? i wouldn't mind upgrading to a billet wheel if it is proven to give gains and worth the $$ spent.
Totally, no idea why people still aren't totally convinced when a lot of people (including Nissan) obviously swear by it. Proof has been posted and lots of credible people have stated time and again that its well worthwhile, it should be as clearly defined as is the fact that a turbo helps our cars make more power and torque.
<edit: Sorry, missed you had already responded - but still, VCT fully makes a worthwhile difference, I've seen ~10% gains for reasonable portions of the rev range by tuning it properly... and a couple hundred rpm or so improvement in spool>
And yes, how did it go Jez?
LOL WOT
Ask your tuner if he has ever dismantled an engine... VCT ventures down and decides to visit piston.. Hello piston, I am VCT.
If the tuner literally thinks that when VCT is engaged that the valve timing is causing the valve to make contact with the piston than you have a serious issue. You should have lost compression on all cylinders in that case. Devastating result.
If our VCT is noisy when it is engaged then you will need to test 3 things: is power/signal constant to VCT or inconsistent causing it to flicker on/off? Using stethoscope type tool listen to: VCT solenoid and see if thats the noise OR try to listen to cam actuator and see if that is the noise.
If the signal to VCT is constant when engaged and it is clicking away, either the solenoid is rooted or the actuator. If the signal is inconsistent the click could be the VCT constantly disengaging and re engaging, which would be an electrical issue. Then again if the solenoid was electrically screwed it could also have high resistance causing the signal to trip out and then try re engage etc.
Back to the drawing board.
  On 10/02/2012 at 1:48 AM, GTScotT said:
LOL WOT
its a tapping noise, not a clicking noise that a vct solonoid makes.
he doesn't want to run it anymore with it engaged incase it causes major issues to the engine.
so really just looking around if anyone has had this issue and if theres any solutions for it.
want to know what im up for before and if i do decide to rip the head apart to have a look.
quite funny that the first tuning place who installed my ecu and put the run-in tune in did not pick this up or advise me of the issue- love their tuning capabilities (if they even did a run in tune!)
my comments still stand regardless of if its a tapping or a clicking, if its a tapping its more likely to be mechanical than it is electrical and again more likely to be the cam actuator more than it is the solenoid.
have you got a spare VCT cam gear (actuator) lying around to give it a go?
I just think its nonsense that the VCT engaging can make the valves hit the pistons. Unless the cam timing is out.
cam timing isn't out, he double checked it when he thought that was the initial issue.
he confirmed the noise was coming from inside the motor and not around the solonoid or cam gear area but willing to swap the cam gear over to try it out.
narh i dont have a spare VCT cam gear, is the cam gear from a r33 rb25 same as r34 rb25 neo?
anyone willing to lend me one to borrow so i can test?
Ok no Dyno for me :(
Lets just say DO NOT BUY A vband to 38mm wastegate adaptor cause there is no way to bolt it on and fit the v band or visa versa. They havent allowed enough room, i only had an hour this arv before i was heading to the dyno and didnt have enough time to pull the manifold off to fit the v band. Ill replace the gate next weekend.
DEVO
Added 15kw in the midrange for me, pretty huge improvement.
  On 09/02/2012 at 7:35 AM, Roy said:
So I am trying the FP Green 73HTA compressor on my TD06L2 turbine and 8cm housing. Who is going to give their TD06L2 to ATP in Melbourne for one of their billet wheel upgrades?
I am waiting for a reply to my email at the moment. Real keen to see which of all these turbos makes the numbers or whether all their claims are hype.
Here is the claimed difference between their billet 20G wheel replacement (anodised Gold) and the std 20G compressor.
The above is on an EVO so you could almost add 30-40rwkws for an indication of what it would make on a Skyline
The claim that they also make 30kws more then the FB Green compressor which is a little alarming since that is what I have :( The wheel looks as close to identical to the BBK billet compressors only gold vs blue.
I would if i were a little closer to actually fitting it , my setup is fairly similar to yours so results (assuming dyno are setup similar) would be comparable . Or are you looking for someone to lend you their turbo for you to use in your comparo?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
