You answer your own question the h has a bigger turbine wheel I had the td06h-20g on my 20 and was seeing full boost at 4200 18psi so it's only a few rpm if you want bigger numbers
Not really. Ill word it better this time lol.
In terms of 350KW going the 12CM housings on the TD06SH 25G and the T67 25G both can do it but would the TD06SH bigger wheel (more lag) would it be worth it for the extra power it make. As if it makes say 15more HP with much more lag then it wouldnt be worth it?
But i cant find much info comparing the 2 or in 12cm housings, so im just asking opinions.
If you were looking for a easy 350KW on 98 would it be better to go as TD06SH 25G 12cm or T67 25G 12cm?
Is that a fair statement? An easy 350rwkws on 98? I suspect it would take 20-22psi on a well tuned RB25 to make that power....I still go by Dyno Dynamics numbers...I dont know if that makes a difference but I think you can say the T67 and TD06H-25G will both make an easy 310rwkws at 16-17psi. The "H" version may make in the vicinity of up to 10-15rwks more?
I am not sure that going to a bigger exhaust housing will also give you significantly more power as the 10cm doesnt appear to be a restriction. Agree that if you went from a restrictive housing to a more free flowing housing you would bet results.
I suppose I am a bit of a scratched record but think we should all be careful about throwing numbers around, especially numbers that may be a little high
The td06 is a good turbo fairly responsive yet gives good top end the td06h-25g is bigger then the t67
Well I noticed one of the guys is making 400+ kw off his t67 and my aim is around 300-350. So maybe I need to look at the 20G instead of the 25G?
Simon's car is an animal and makes whatever power it does...its a big number because the thing runs 11 flat on the quarter and blitzes around race tracks. He has various dyno sheets from various shops where the car has been run. He runs a 50:50 E85 mix, so that helps with power, but still not a full E85 tune (is there much difference in outright power? I got no idea...but I know its helping his power over std 98)
I think it was a dynapak that put it at 410rwkws. A dyno dynamics put it at 480rwhp (or 360rwkws)...so as BSA GTScoT and others have been saying...do your own research and look at other sources rather then just SAU. If you want 350rwkws from an RB25 I think you need to push a 25G based turbo.
the way I see it, the last thing the h wheel will do is add power anywhere in the band. What it will do is add a little more scope to the compressors maximum flow.
Simon has already noted that his compressor has maxed out before the hotside, what more do you need?
that being said its no science to see the h wheel will be application specific. For example if i wanted blitzing 350kw and i put a t67 on a bad ass rb34 but the thing maxed out at 5500rpm, i would know the restriction was in the hotside. I would then try move to a larger housing, and if that did not yield the result inwas after I would then move to a h optioned unit.
Obviously the idea is bring the thing on later and keep it on longer. It would be trial and error between 10cm H or 12cm L2 in my eyes.
And again Simon is reving his to 8 with no sign of turbine cap. Now lets all forget about the h turbine until someone builds that bad ass rb34 i mentioned.
Roy is pretty much spot on here... 410kw at the hubs on a happy hub dynapak 360rwkw on a dyno dynamics roller.
My mix has a huge advantage over a 98 tune. It probably would not make any extra power with E85 as we can wind as much timing as we want in without detonation as it is
I think it may be maxed out, don't know that for sure... May be another issue, either way I don't really need any more power
In saying that, I may be going from Nistune to Vipec and dropping some cams in soon... Someone stop me FFS
24-25psi and that would the least amount in that turbo sizing..
cheers
darren
... may be going from Nistune to Vipec and dropping some cams in soon... Someone stop me FFS
Why the change from Nistune to Vipec? I Interested to know what cams you are looking at as well. I would be tempted to stick with the std inelt cam and go baby 256 exhaust cam
Remove the AFM from the equation... The Z32 is out of its depth already and makes the cooler piping a lot better!
Cams would most likely be a set of poncams.
cheap ponnies on american ebay atm mate autocat51 is the seller..
http://www.ebay.com.au/itm/Tomei-PonCam-Cams-Camshaft-ECR33-R33-RB25-RB25DET-/190486773888?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c59e58080
Neo
http://www.ebay.com.au/itm/Tomei-PonCam-Type-B-Cams-Camshaft-R34-RB25-RB25DET-Neo-/360291534189?pt=Motors_Car_Truck_Parts_Accessories&hash=item53e30c856d
I got Neo ones and they where $640 to my door...and delivered fast..
cheers
darren
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
