lol, i started using e85 about 3 years ago now on a half assed touch up tune that took 6 runs (later was retuned by someone better) never even changed my fuel filter and drove it daily on e85 for ages... never had even 1 problem. not 1
it does indeed seem that the only people that have had troubles with e85 are those that have never used it... lol
Been thinking about dropping in some new valve springs while the turbo issue is being sorted., performance springs sell two kits one is rated for 9mm lift the other 10mm... Which kit should I be looking at to run in my setup with stock cams??
Interesting, a friend had HKS cams in his RB25 that deleted the VCT and its always dangerous to judge and form an opinion on the basis of one car but perhaps there was maybe a difference in throttle response and maybe 100-200rpm, hard to tell with the change in cams...but not 500-1000rpm. I would expect the 500cc, 0.5 bump in compression and VCT would at least give you at least a 500rpm improvement
not at all, we did brents car way back i thik when we sold cammtech cams (great cams too btw) and i spent hours getting the cam timing to the point it lost very little.... BUT i can tell you now if i do one run with it on and one run off on the dyno the differrence can be huge. (more power and torque).. just ask tao, we have is car in every fortnight and one night were chasing a 500rpm lag issue between tunes and it turned out the vtc plug had vibrated off.
Every tune we do that has vtc get a run with it off and run with on constantly (but not a full pull to redline when on constantly) the intersection point is easily discernable.... in power and torque terms that is.
So seems like Eiji isn't interested in replacing this china junk turbo. He ain't responding to my messages...
Last thing he said was that he'd be happy to sell me a new turbine wheel and if i send it to them they would fit/ balance it for free. Then I got angry and now he won't reply lol
I'm in the same bad customer boat. A wrong oil line was supplied with my kit so emailed and asked how we can go about getting me the correct line, no response! Service was great until I payed but now seems to lack quite a lot.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
