Yes, those are the correct housings.
I would LOVE to see back to back results :) Please be the one to dyno before and after! For your own benefit also.
Will do, I already have the before dyno sheet up in the rb25 dyno thread, I'll do the after one as soon as I get in the dyno again, kinugawa has only just shipped my comp housing but i haven't orded the exh housing yet because I'm not sure if the larger exhaust housing is going to mean I need a new Vband exhaust setup, maybe it will need to be re made bigger ? Which I canT afford just yet.
Here's a wee GoPro clip from this weekend, mate's S14 running the TD05-16G (anti-surge housing version) doing a street sprint around an industrial area, ultimately a low speed "circuit" so this clip isn't really one to show outright power so much as show how usable the power that these things can bring to the party is. The car is using G4 Link boost control setup up to run wastegate boost in 1st and 2nd gear, and ~16/17psi in 3rd - in an effort to keep the car from trying to make it look like a D1 event :) Even with this setup the car was quite excitable in 2nd gear, the owner ended up finding it quicker to keep it in 3rd gear for most of the track - which is where I am coming from showing this clip. For such a cheap turbo capable of hitting high 200rwkw fairly happily I reckon the transitional response and also low down pull (there are corners here where it is usefully accelerating from around and even under 3000rpm) are very decent.
  • Like 1
The housing will go on just fine. As long as they are both V band.
It would be awesome if you put on the front housing first and just did a power run to document the difference.
if anyone is interested, i have a TD06-20G 3" anti-surge housing lying around with less than 200km usage on it.
same as this http://www.ebay.com.au/itm/Kinugawa-Turbo-Compressor-Housing-Mitsubishi-3-TD06-25G-with-Anti-Surge-Inlet-/111129184823?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19dfd0ca37&_uhb=1
will sell for $100 postage anywhere in Aus.
Here are the specs,page 271 of this thread you can find the dyno graph
R34 GT-T 4 Door
Internally stockarrow-10x10.png Neo motor
Splitfire coil packs
HDi cooler w/custom piping
3" exhaust w/100cell metal cat
Tomei type A poncams
MSLR head gasket
Arp head studs
PnT Performance intake manifold w/r33 s2 throttle body
650cc Siemens Deka Injectors
Aeroflow high flow fuel rail
Turbosmart FPR800
Hybrid Performance top mount exhaust manifold
Turbosmart Compgate 40
Kando TD06H 60-1 w/anti surge front housing and 10cm rear
Gizzmo IBC
Nistune
After matsuri ill go about ordering one of those normal housings and then get a dyno run done again.
My bad! I totally forgot that.
That's a very interesting combo. Being a H wheel I wonder what an 8cm housing would be like... It would cut the rev limit down but I feel it may potentially make it a torque monster. Maybe then the anti-surge housing would pay off lol
I run a bov any ways,only reason i got the antisurge was that kando had a sale on ebay,$711 shipped to my door.for $160ish its worth a shot as im now using the car for drift and starting to learn in a car that only comes on boost at 4000 is a bit of a challange,my tuner (cece @ jaustech) says that if i go to a 6boost or similar it would improve my power curve and also spool quicker aswell,not surd if 4000 is slow or quick for my setup lol
Lol 4k is a good figure for anything at that sort of power level, its the motor naturally coming alive without being hampered by a laggy turbo. BUT what happens before its 'all in' is also important.
I find that a setup which is all in at a point like 4k on a modern DOHC is quite good if it has a reasonable amount of sting below 4k. If below 4k is a bit of a dog and it all happens at 4k you might want to work on it..
For my own car (SS1PU SR20) it definitely all happens at 4, that's where the party is at, but it gets to 4 really happily and freely. Getting it onto power feels like it didn't happen, by the time your expecting power the car will be demanding all your attention as you hit warp 9.
I hope that helps.
Yeah that does help,its not a slow journey to 4k,quite quick in fact,this is my first car making this sort of power and ive modified it from stock but from my previous mods to the ones stated ive jumped 100rwkw lol i didnt think 4k was that bad as std is arlund 3200ish? So 800pm later and 150rwkw more then stock isnt too bad,still keen to test the whole antisurge vs normal housing theory out.when i was coosing turbos i favoured the 10cm over the 8 as the 8 seemed better for smaller engines(e.g 2ltrs) and the deciding figure was the cfm of it as it out flows a 3076r at the same boost levels from what ive read.will post results when ive got my stuff sorted ;-)
All the more reason to try a few things Stormy!!
By all accounts funki_munki should have the laggier turbo, so there is something lacking on your setup.
yeah well im gonna give the non anti-surge housing a go first and do a dyno run, then ill throw the 10cm rear housing on and see what it does. My tuner ( andy @ hyperdrive ) said that my high mount manifold has a really crap design, which is fair enough as its just a china spec ebay thing, i would get a 6-boost but i really cant afford that right now.
Eventually ide like to get the 6 boost and a non-china wastegate to match, and also some cams. I want to hit 400+ on bp98 before i move to E85, i cant do E85 right now as im only running 550cc inj.
haha funny thing is I lost a shit load of response and torque goin from my hybrid manifold and tial 44mm gate, to a brae performance manifold (ie long runners ,merg collector like a 6boost) and hypergear 50mm waste gate. I did make a lot a lot more top end though even on 3-4 psi less. Also required less fuel. think around 10% a lot more efficient
So don't slag the hybrid lol.
Harris can you elaborate on your setup? Presuming a Kinugawa turbo of some description.
Did either one present with boost control issues?
Would you care to post any dyno overlays of the Hybrid vs Brae if available?
Don't really want to deviate off topic but it might be worthwhile giving your feedback/experiences to Brae
Im using a hypergear 22.5g (I think thast what it called). Its an l2 turbine wheel and 10cm rear. The comp wheel is Staos billet 11 blade ss2 wheel , .7 front non antisurge housing. Flows about the same as a t67 with slightly better response.
with the hybrid manifold and tial 44mm , the spring combo used boost creped to around 23-24 psi and tapered of slowly to wards redline. Also had a larger gate pipe welded to the manifold
With the brae manifold and 50mm gate, its seems to build boost fair bit slower, but was more efficient up top. mad more power than previous manifold and gate on 20 psi. peak power is closer to redline, aslo used 10% less fuel
I got rid of the hybrid because it kept on warping the head flange and leaked. A piece of the weld from the collector also broke off and damaged the turbine wheel. So bit the bullet and bought the brae( Staos old setup of his test car).
Bit trickier to drive with the lag, but pulls a lot harder. Cant wait to slide on the track
Got one run in at calder park managed an 11.7 at 121mph, pretty happy considering its setup for drift , abit more practise think i could run a high 10 second pass
I have the dyno plot comparing the two but not too sure how to upload it
pink is current(brae with 50mm),
Edited by dori33
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
