Yes, those are the correct housings.
I would LOVE to see back to back results :) Please be the one to dyno before and after! For your own benefit also.
Will do, I already have the before dyno sheet up in the rb25 dyno thread, I'll do the after one as soon as I get in the dyno again, kinugawa has only just shipped my comp housing but i haven't orded the exh housing yet because I'm not sure if the larger exhaust housing is going to mean I need a new Vband exhaust setup, maybe it will need to be re made bigger ? Which I canT afford just yet.
Here's a wee GoPro clip from this weekend, mate's S14 running the TD05-16G (anti-surge housing version) doing a street sprint around an industrial area, ultimately a low speed "circuit" so this clip isn't really one to show outright power so much as show how usable the power that these things can bring to the party is. The car is using G4 Link boost control setup up to run wastegate boost in 1st and 2nd gear, and ~16/17psi in 3rd - in an effort to keep the car from trying to make it look like a D1 event :) Even with this setup the car was quite excitable in 2nd gear, the owner ended up finding it quicker to keep it in 3rd gear for most of the track - which is where I am coming from showing this clip. For such a cheap turbo capable of hitting high 200rwkw fairly happily I reckon the transitional response and also low down pull (there are corners here where it is usefully accelerating from around and even under 3000rpm) are very decent.
  • Like 1
The housing will go on just fine. As long as they are both V band.
It would be awesome if you put on the front housing first and just did a power run to document the difference.
if anyone is interested, i have a TD06-20G 3" anti-surge housing lying around with less than 200km usage on it.
same as this http://www.ebay.com.au/itm/Kinugawa-Turbo-Compressor-Housing-Mitsubishi-3-TD06-25G-with-Anti-Surge-Inlet-/111129184823?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19dfd0ca37&_uhb=1
will sell for $100 postage anywhere in Aus.
Here are the specs,page 271 of this thread you can find the dyno graph
R34 GT-T 4 Door
Internally stockarrow-10x10.png Neo motor
Splitfire coil packs
HDi cooler w/custom piping
3" exhaust w/100cell metal cat
Tomei type A poncams
MSLR head gasket
Arp head studs
PnT Performance intake manifold w/r33 s2 throttle body
650cc Siemens Deka Injectors
Aeroflow high flow fuel rail
Turbosmart FPR800
Hybrid Performance top mount exhaust manifold
Turbosmart Compgate 40
Kando TD06H 60-1 w/anti surge front housing and 10cm rear
Gizzmo IBC
Nistune
After matsuri ill go about ordering one of those normal housings and then get a dyno run done again.
My bad! I totally forgot that.
That's a very interesting combo. Being a H wheel I wonder what an 8cm housing would be like... It would cut the rev limit down but I feel it may potentially make it a torque monster. Maybe then the anti-surge housing would pay off lol
I run a bov any ways,only reason i got the antisurge was that kando had a sale on ebay,$711 shipped to my door.for $160ish its worth a shot as im now using the car for drift and starting to learn in a car that only comes on boost at 4000 is a bit of a challange,my tuner (cece @ jaustech) says that if i go to a 6boost or similar it would improve my power curve and also spool quicker aswell,not surd if 4000 is slow or quick for my setup lol
Lol 4k is a good figure for anything at that sort of power level, its the motor naturally coming alive without being hampered by a laggy turbo. BUT what happens before its 'all in' is also important.
I find that a setup which is all in at a point like 4k on a modern DOHC is quite good if it has a reasonable amount of sting below 4k. If below 4k is a bit of a dog and it all happens at 4k you might want to work on it..
For my own car (SS1PU SR20) it definitely all happens at 4, that's where the party is at, but it gets to 4 really happily and freely. Getting it onto power feels like it didn't happen, by the time your expecting power the car will be demanding all your attention as you hit warp 9.
I hope that helps.
Yeah that does help,its not a slow journey to 4k,quite quick in fact,this is my first car making this sort of power and ive modified it from stock but from my previous mods to the ones stated ive jumped 100rwkw lol i didnt think 4k was that bad as std is arlund 3200ish? So 800pm later and 150rwkw more then stock isnt too bad,still keen to test the whole antisurge vs normal housing theory out.when i was coosing turbos i favoured the 10cm over the 8 as the 8 seemed better for smaller engines(e.g 2ltrs) and the deciding figure was the cfm of it as it out flows a 3076r at the same boost levels from what ive read.will post results when ive got my stuff sorted ;-)
All the more reason to try a few things Stormy!!
By all accounts funki_munki should have the laggier turbo, so there is something lacking on your setup.
yeah well im gonna give the non anti-surge housing a go first and do a dyno run, then ill throw the 10cm rear housing on and see what it does. My tuner ( andy @ hyperdrive ) said that my high mount manifold has a really crap design, which is fair enough as its just a china spec ebay thing, i would get a 6-boost but i really cant afford that right now.
Eventually ide like to get the 6 boost and a non-china wastegate to match, and also some cams. I want to hit 400+ on bp98 before i move to E85, i cant do E85 right now as im only running 550cc inj.
haha funny thing is I lost a shit load of response and torque goin from my hybrid manifold and tial 44mm gate, to a brae performance manifold (ie long runners ,merg collector like a 6boost) and hypergear 50mm waste gate. I did make a lot a lot more top end though even on 3-4 psi less. Also required less fuel. think around 10% a lot more efficient
So don't slag the hybrid lol.
Harris can you elaborate on your setup? Presuming a Kinugawa turbo of some description.
Did either one present with boost control issues?
Would you care to post any dyno overlays of the Hybrid vs Brae if available?
Don't really want to deviate off topic but it might be worthwhile giving your feedback/experiences to Brae
Im using a hypergear 22.5g (I think thast what it called). Its an l2 turbine wheel and 10cm rear. The comp wheel is Staos billet 11 blade ss2 wheel , .7 front non antisurge housing. Flows about the same as a t67 with slightly better response.
with the hybrid manifold and tial 44mm , the spring combo used boost creped to around 23-24 psi and tapered of slowly to wards redline. Also had a larger gate pipe welded to the manifold
With the brae manifold and 50mm gate, its seems to build boost fair bit slower, but was more efficient up top. mad more power than previous manifold and gate on 20 psi. peak power is closer to redline, aslo used 10% less fuel
I got rid of the hybrid because it kept on warping the head flange and leaked. A piece of the weld from the collector also broke off and damaged the turbine wheel. So bit the bullet and bought the brae( Staos old setup of his test car).
Bit trickier to drive with the lag, but pulls a lot harder. Cant wait to slide on the track
Got one run in at calder park managed an 11.7 at 121mph, pretty happy considering its setup for drift , abit more practise think i could run a high 10 second pass
I have the dyno plot comparing the two but not too sure how to upload it
pink is current(brae with 50mm),
Edited by dori33
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
