Odd, I ran a freddy manifold on my RB25 with a GT3076 at 18psi.
RB25 - 314rwkw 750nm torque
RB25/30 - 320rwkw / 850nm torque
Ahhh, just read that you have a RB20. Surely that won't make too much of a difference?
no im running a stock rb25 motor with arp head studs camtech 272 cams. yeah not sure, might be dyno who knows. its never seen that kind of nm. similar setup cept plazaman gt3076 .82 and e85 made just under 600nm on same dyno. who knows. see how it goes at drag day in september. should trap ok mph im hoping. the cams are suited for a larger rev range, i only go to 7200. these might make more torque over that,but stock motor , keep it at 7200 so it stays together
Edited by methz
Definitely something wrong with that torque reading. Mine was done on two different dynos, and same reading.
So don't lose faith in your freddy manifold just yet. You'll find that is not the problem.
Power is up there - just the torque is not quite right. MPH will definitely be an indication of what you're really running.
Good luck!
I'd imagine you are talking about a dyno dyanmics torque reading (tractive effort)? You can't compare that to a dynapack...
Mine made 590nm on similar power so methz result is just about spot on
Edited by SimonR32
Mine was one dyno dynamics, and the other was a mainline, both had similar readings
  • 1 month later...
Hey guys flicked through this thread but just chasing info...
Had a kando on the Sr and now picked up a pooline. Just wondering whether the 4inch covers on the td06 25g fit low mounted. Aside from a spacer plate and extended studs I'm wondering if they foul on a stock rb25 manifold anywhere. I know the 3inch fits indefinitely but I already have some cooked Chinese low mount unit on there now with a 4inch pipe that I'd like to reuse if possible. Cheers
  • 4 months later...
Thread revival.
I've been away from skylines for far too long and I'm coming back. Looking at these turbos again and can see they have the new bolt on internal gate versions with the adjustible gate.
Are there still boost issues if running Internal? Td06sl2-20g in 8cm for response and direct bolt on.
Mods: 550cc nismos, z32, nistune, other usual bolt ons.
Any input would be good. Or am I better off going hyper gear?
Chasing 250-279
Hypergear internally gated Rb turbos are definitely better, and so's externally gated. check out other member's results in their thread.
I disagree. Kandos are the next best thing to precision and garett. So cheap, and well built.
just proof there i've been away for too long, i called the actuator - 'gate'
hmm ok 10cm internal gate, any dyno sheets with stable boost? looking to run 18~ psi on unopened RB25DET.
I'm posting this to save you some money. This is a kando TD06 in a 10CM turbine, notice the boost creep and tapper.
and I have received many of turbine housings of this kind to re-work on its internal gate. From the way of how the turbine housing is cast, internal gate can not be effectively enlarged either.
Depending on how much power you are targeting. our STD high flows in most of cases can reach your goal with better performance and longevity.
21U STD high flow, E85 fuel.
Perfect boost control. Internally gated.
Thanks Tao, i've been in contact you on FB via PM about the hiflow as it looks to be the way to go
unless there is other evidence and feedback with the int gate with kando, will be going hypergear. i had their ext gate setup and it was great. but want to keep it all factory looking now
Cheers
Anyone had a turbo highflowed with one of the kinugawa GTX compressor wheels? I have a pair of -5's that i wouldn't mind cramming GTX67 wheels into.
http://www.ebay.com.au/itm/Billet-Turbo-Compressor-Wheel-Garrett-GTX2867R-49-7-67-4-Trim-55-11-0-/271774042157?pt=LH_DefaultDomain_15&hash=item3f46fec82d
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
