in the exact post you replied to he said they are both 99 ron lol
Tony de you would probably find that the 5% ethanol wouldnt be that great... while ethanol has good ping resistance it is only seen in high quantities thus far, and it will probably be more consistent for u to run straight 99 as the ethanol will result in a leaner burn.
The E5 is also more likely to be a lower grade fuel and the RON bump is from the ethanol, again probably a mask in this case.
I would like to see atleast an E10 variant added to regular PUMP (98 RON in OZ case). Price would stay about the same but we could pick up some ping resistance and have a better RON rating.
so if i want 300rwkw out of a rb25
what would be better one of this kando turbos
or a garrett gt3076r 56t with 44mm external gate
both on a low mount without cams but all supporting mods
with bp98 fuel
Edited by jet2nv
ive had a read through it but theres over 100 pages from what ive seen i think im gonna go a 3076 just wanted some peoples opinions
Peoples opinion on what? a gt 3076 (which one??) or kando? or vs a kando? or vs a NA civic?
be more descriptive mang
Edited by Rolls
if you read the previous 2 post you would see what im asking i know theres different types of kando and 3076 but i want to know which oneis better for my stated power goal
For 300kw you will need a T67 from kando or the 3076.
The 3076 is likely to be 'more responsive', but once on full song it appears the T67 walks away and ends up with more power.
As a rule of thumb on 98 you should expect 280-300 from the 3076 or 300-330 from the T67 on roughly 20psi each. If you are planning to go external gate you should probably just take the T67 as they are freaking cheap but if u want internal you must get a 3076.
You can also look at a hypergear G3 (much cheaper than both of the above and is also a solid performer - close to 3076 numbers a little laggier).
yeah im extremely familar with stao and his turbos ive know him since he first started and tried ALOT of his different turbos yes they make good power reliable cheap but im more concerned about resale and response the turbo from stao which is very close to the gt3076r is pretty much the same price i get the gt3076 for i already have a dump pipe braided lines and everything ready for the garrett
so yeah i could sell it all and try but after trying a g3 and a gt3071 and the 3071 making 280 and super responsive i think the 3076 is the smarter way to go unless someone here has tried all 3 maybe lol as most motors/dynos are different
I dunno but the HG SS2 also looks to be in GT3076R territory, just my opinion..
A TD06H-25G is bigger than a T67. I may be going one of these on my Rb30. Just trying to decide on what config I will go. IE 10 or 12cm turbine housing, TD06 or TD07 compressor housing, Port shrouded or unshroaded and cast or billet compressor wheel.
any 1 wanna put there POV forward?
Edited by urtwhistle
12cm for Rb30....
cheers
darren
how laggy would a gt3582 with a anti-surge a/r70 wuth a .63 rear be compared to a gt3076r .82 if my goal is only 300-310rwkw max
welcome to the kando dynamic thread, where we talk about kando dynamic turbos.
Please ask a question about a kando product or go to the Garrett thread. There are a number of threads dedicated to gt30 based turbos where your question would be entirely relevant.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
