lol why you hating Dale?
its already an ARX, doesnt need to cop more flack! where is the love :iluvff:
No hate mate, it totally changes the look, but when you make moustache references, it just just reminds me of this;
The gay bit: that car looks like a gay swiss guy I used to work with...
'Cept his name was Bruno.
Edited by Daleo
well i got up late this morning, and was already late for work so thought f**k it, im gonna fit this grill
looks good, im kind of happy i didnt colour match as now it works well with the ARX gaynus styled moustache :ph34r:
tell me what you think?
Like the headlights!
Edited by Jetwreck
syn-x 3000 is in, sounds nice
will drive it soon but i think it should be good, just letting the oil drain down from the head to check the level
$40 all up for a oil/filter change is pretty good i reckon
Something arrived today....
My car has a Turbo in it Brah!:P
Hey Alex, that looks like the easiest turbo install ever. Step 1) Place cardboard boxes in rear of wagon. Step 2) Done
Can't wait for the extended version. Good luck.
:blink:
I knew Scotty's been whining about nothing!:nyaanyaa:
That install looks like a piece of piss!
It does seem to have compromised passenger space a little... Silky Terrier now? LOL!
Edited by Daleo
You're right. All I ever hear from Scotty is that there's not enough room for a decent turbo. Just look at the size of those boxes and still some room to spare.....
can I come over and play!!!!!!
sorry scottiluvff.gifI have a new friend!!!
Edited by Jetwreck
There is just enough room for a TO4e compressor housing, or a GT30 4 inch. It will be tight but the Tial turbine housing will help fit it all in. Thats a decent size isnt it? :)
Remember most of that kit wont fit, like the intercooler and a majority of the piping. Engine out most probably to fit the manifolds and rear exhaust crossover although it may be possible if you strip the plenum right down, not a job I would like to try though. Lots of skin off the knuckles coming up buddy, have fun. I love the pain. lol. :thumbsup:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
