Same size motor as a m35 stag. 2.5lt V6 but this ones a 2 stroke.
puts out more power tho its good for 200hp and about 80-85mph on a calm day. :nyaanyaa:
Edited by Big Fella
Was it hard? Fitting mine tomorrow lol any tips?
It wasn't too bad. The only problem I had was I thought the lines that came with the kit were a little short for my liking. However, still more accessable than what the oil filter was before.
I also had to cut down a brand new Stanley 300mm adjustable spanner to fit under the intake plenum. It is now more around 120mm :laugh:
Rhet fuel filter has 6mm bolt,
You need more then that mate,
put filter down so you don`t pour Oil everywhere ,
plastic bag :stupid:
if your still worried PAPER BAG TOO :thumbsup::cheers: ,
what size lines are you using ?
are you boys still using 2 filter as thats a SMALL FILTER
Got nistune done to the car today. Pretty happy with power gain, was 135kW before the nistune. Very smooth delivery!
Excuse my C34 ignorance but shouldn't you be getting more torque? Power looks great! Just was expecting a different torque curve...
Was thinking the same thing when I saw it!...Hp figure is good...the nm figure does not make sence.
Wouldn't have a clue! I got Shaun to tune for economy for what it's worth. Apart for a smooth curve I'm not sure what's what on the print out.
That's a pretty impressive gain. Was it just the tune or have you also added bigger exhaust, more boost or any other mods? Good advertisement for Nistune. - OK just saw your other post - now for an upgraded turbo!
Yeah just Nistune. If this also translate to better economy it's be great!
Edited by webng
Finally the Stageas coilovers turned up..
Rears are in! oh what a feeeeling.. should have done this ages ago..
fronts going in today!
And then maybe do the Emo ones too if i can be bothered today..
Installed New Alternator and Power Steering belts today.
Also adjusted the front sway bar to a stiffer setting now that I have some tires with a little grip. :)
Diagnosed another problem of a big hesitation around right hand corners.. time to replace the Walbro fuel pump. :(
Whats wrong with the fuel pump mate? Did you end up running full voltage to it? If its in the stock housing it shouldnt cut out at all as it sits in a cup in the tank, is it when low on fuel or all the time?
No, Stock power supply.
When I drive around right hand corners and I give the car a bit of throttle (usuall in 1st or 2nd) I get a big hesitation around 3-4k rpm. The car settles and then continues on to higher rpm.
I took Craig for a drive and he thought it felt like the fuel pump as he though his did something similar before it failed.
Not sure if it is all the time but I am usually conscious of it when the tank is 1/4 or lower.
I have the option of changing the pump tomorrow whilst fuel is low of filling up tomorrow and seeing if it still persists with a full tank.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
