Still not sure where I want to take it, everyone says go to efi but their prices are a bit high, I've had bad experiences with recommended tuners before, the people with no recommendations are always more willing to fix their mistakes.
That's if your engine survives their mistakes!!! Do you want to risk a $10,000 rebuild for the sake of a few hundred dollars? The tune is the most important element in the process.
i see your point, judging by how its running now it will only need a quick touch up anyway. im gonna give efi a call tomorrow and get it booked in. just a question, ive never had a car tuned that didnt have a boost guage, should i temporarily install the one from my wifes car for the tune??
My cars tuned and it still doesn't have a boost gauge
:P
I attempted to help Brad install my headrest monitors, we got them all in and got the headunit fixed up. Now we have 4 screens running for our trip over to Melbourne for Gymkhana :thumbsup:
Brake rotors were finished and sent Friday, so just waiting for them to arrive and fit up. Waiting for lots to arrive at the moment...
Want to do mine? I'm so bloody lazy...:rolleyes:
bit of a prick to do but luckily cos i have the plenum spacer i didnt have to take the inlet manifold off too :)
about a 3hr job taking my time to do it carefully.
disconnect all the wiring around the left bank.......... because i disconnect the cam sensor is that going to cause a drama when i go to start it up again ?
Yeh, I've got the spacer too.
I'll be doing mine this week I think. You shouldn't have any issues with engine light as long as you don't turn on the key with any wiring disconnected.
4? where's the forth one mounted?
How hard is it to do these headrest screens? how do you run the cable through the seat?
I have the standard one in the dash, and the 7" pop out one in the headunit. Plus two in the headrests.
Headrest screens aren't that hard, but I sucked at it. Brad was running wire through the seat backs, because there is a void in there, but I sucked at getting the wire through the seat, because there's the metal frame you have to work around.
You need patience to do it, and I don't have enough >_<
I've got a mate who works at Tower Audio who'll do it but he's pretty busy. Not sure if I'm brave enough to attempt this myself...
Might just stick with wifi streaming for the time being
Don't you just unzip the cover at the back & lay them in? Anyway,that will keep the passengers entertained.
And you have a heap of stuff coming if I recall - you are going to be a busy lad over the next little while.:happy:
Apparently they're a pain to rezip and resecure, so we used wire. Not too difficult really, just have to be patient threading the wire through.
Yep, big collection: Rotors, braided lines, shift kit, BCs, wireless reverse camera being the main stuff. Also got pads, adjustable rear toe arms and Informeter which still haven't made it in. Looking forward to getting it all installed :thumbsup:
Headrests are not that hard to put in. Like Ryan said you need patience. I fed a banana shaped bit of wire down the back of the seat. Some times you get it first go other times I just want to throw tools. And if you unzip the seats and undo the plastic lip at the bottomm its a bitch to get back together.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
