swapped the transmission over yesterday with the 'good one'
big thanks to craig (jetwreck) and andy (andy65b) for their assistance.
the box is pretty much the same, just lacks that overdrive lockup problem which was a massive pain in the ass.
cant wait for the shift kit to go in!!
I hate the way the convertor clutch locks up so early. Previous jap nissans I've had they don't lock until your over about 85km but the m35 seems to lock at about 60km or lower.
Edited by slippylotion
+1.
Around town or anywhere up to about 90km/h, I flick the stick across into 4th; locks out top gear and is generally a bit more responsive.
Doesn't kick down as easily, but I don't find it too much of an issue; much better than constantly shifting up and down all the time, because you can't maintain 70km/h...
I disconnected the torque lockup two years ago, The high stall converter keeps revs up over 2500 when cruising and shoots up to 4k fairly quickly once boost kicks in. I pay the price with less fuel economy though, I still need to fit a switch near the gearstick to lock the converter on long drives.
Speaking of overdrive, is it just me or do these things want to be in 5th gear asap. Cruising at 60kmh in overdrive at 1000rpm seems kinda stupid..
once the box went into lockup, if it was in it long enough it wouldnt come back out of it
and yes they get into 5th quickly, but i find now if i move my foot a little it will kick back no problem.
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Hey Ross, what exhaust did you put on? And I like your wheels - car looks great mate.
Picked up my autech on Sunday morning and fitted some 20" rims I had laying around straight away lol. Hopefully getting front pipe, highflow cat and and 3" cat back fitted this week
we want pic's!!! :P
Thats a good time.
1st owner of my stag (CoolPC) ran a best time of 16secs, with catback exhaust k&n pod filter & 10psi
Would love a strip in Sth.Aust to see where it'd be nowadays.
Once the engine is refitted, of course.
$4k is the rebuild price, including engine out/in, tune after run-in, CP piston kit, complete block work (bore/hone, acid bathed, etc), head refresh & new MLS gaskets.
Spent about 3 hours scrubbing away at the double sided tape/foam that the japs must have used for aerials. Unfortunately the previous owners never bothered to remove them so they were pretty much rock hard.
Also debadged the rear end.
Going to get some quotes on how much to spray my wing black/spray my new grille and fix a small dent in the passenger door and most likely respray the bonnet tomorrow. Previous owner did some "touch ups" that most people would refer to as graffiti. I'm hoping I can get away with all of that work for under a grand. No idea though..
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
