With the 7psi actuator its hard to run any more than that, even with a controller. You may get 20psi midrange but it will always drop to around 15 by redline without increasing the spring tension on the wastegate.
The exhaust manifold pressure literally blows the wastegate puck open on boost bypassing the turbo hence welding a stiff spring to the actuator to hold it better.
All the stock turbo failures I have seen have been due to oil starvation/heat on the rear bearing as Dale mentioned.
Lol Scotty, I should have referenced you in there mate; it's been your hard work and development that has brought this information to light.
I fitted the dump by itself on a factory exhaust and I'm convinced it makes the turbos life easier.
Speaking of which, Slippy and I were both talking about running a dump on the standard exhaust.
Are there power gains to be seen from running an aftermarket dump on the factory exhaust? Would it be more hassle than it's worth running a custom system from the turbo back to the factory "sports" muffler? I know that the factory exhaust weighs a ton so I figure it's worthwhile getting rid of, but I quite like the fact that I can press a button and my exhaust goes quiet, but if it's going to significantly impact the gains it's just a waste of money trying to keep it..
Yes,, 100% worth the effort.
Standard dump has a cat in it. Which then connects to a mid pipe... with a cat in it... and the massive box of baffles.
If you really want to keep the Nismo rear I'd do dump and mid pipe. But you should see a huge gain just doing dump and midpipe.
Andrew at AM Performance designed his exhaust so that it matches up to the factory mounting locations, so you can buy a dump and midpipe and it should be easy to connect to the Nismo muffler. Or just get him to do it, either way.
This sounds good.
So would the midpipe replace the baffles? I want to get rid of that. Do you know if his system has a cat too? Think it would be a lot louder replacing the standard dump (cat), midpipe (cat) and box of baffles with just a cat?
This sounds good.
If you want it quiet, get a Blitz NUR cat-back and then get whomever to make up a dump and frontpipe/cat to bolt up to the Blitz.
Stock is 82dB
Blitz is 82dB (but 80mm and straight through design. Cheap too)
Everything else is 86db+
Stock is 82dB
Yeah see I'm fine with that every other day of the week, but the little switch is a nice thing to have. Especially while driving interstate to get rid of the drone.
Out of curiosity, what are the Blitz cat backs worth?
Thats what I like about the switch as well
I would be interested in your current system if you upgrade.
I got mine thru Jesse a while back & it cost ~$950. People have reported them for as low as $799 from Just Jap (plus freight?), depending on exchange rates & how many they bring in at a time.
Point to note, exhausts get louder over time as the sound deadening settles down. I'm very pleased I didn't go with a louder one as mine is now probably at the level that most guys would say is what they like, but if it keeps getting louder so help me..... lol.
Also, the tip is a bit on the big side for a 'mature' bloke like me.
Another late one trying to resolve the timing/electrical issue.
I'll attack this again tomorrow night....thanks iain for your help.
Edited by Jetwreck
no worries craig, see you there again tonight!
when we were bleeding the attesa system last night, craig put his foot on the brake and one of my braided brake lines split and pissed out brake fluid.
LUCKILY the old set were still next door. threw them on and im able to drive
just be aware M35 drivers, dont get the cheaper braided brake lines from IM. just get nismo or have a set made up by maltech. actually wasnt someone organising that?? im pretty sure i gave a set to someone to have that done
Front trim off and ECU out, to take down to SAS to see if they can chip it for tuning the Turbo Kit! banana.gif
Fingers Crossed!
Can you ask them for Craig and my ECU back that we gave them 18 months ago to see if they can tune our cars. :(
Faaark!blink.gif You surely dodged a bullet there Iain; could've been a disaster.
Specialised Brake & Clutch in Penrith made me a set of Goodridge ADR legal lines for my last car; they were around $80-$90 each. All pressure tested to ensure things like that don't happen.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
