Not what I did to my stagea, but more what I did WITH it..
On the way to nightwars (a summer drag racing series), threw sparks all over everyone elses cars, popped a couple cats eyes out of the road and now all I can smell is hot metal... Flexi in the exhaust looks worse for wear and so does the rear tow hook... Might need to raise it. :(
Don't do it!:spank: As an extension to the "Don't buy wheels that fit the car; make the car fit the wheels" ethos; I propose a "Make the road suit your ride height" solution.
You just need to keep frequenting the roads you use; until you've worn a groove them all to suit your ride height, no more clearance issues.
Anything still grinding will eventually be worn away; consider these items "Surplus to requirement" Problem solved.:thumbsup:
You're welcome.:whistling:
Edited by Daleo
ok this is what i found............. so basically its a wait of money.
Posted 27 April 2011 - 02:24 PMsnapback.pngironpaw, on 27 April 2011 - 01:55 PM, said:
Anyreason these won't work for our cars?
http://www.importmon...%20NM35%2014750
review: http://my350z.com/fo...-installed.html
They will not remove our restriction.
Ask Scott when you see him next how well it worked in that regard.
snapback.pngbigkevracer, on 27 April 2011 - 02:13 PM, said:
If I read the old discussions properly though, Mines wouldn't remove the throttle restriction.
I figure we're not going to get a flash that does everything we want, but a flash that removes the speed limiter and throttle restriction and gives us 80-90% of what we want is fine with me. And when I want that remaining 10-20%, I can get an emanage knowing that the two main areas it can't fix are sorted from the flash.
Mines completely remap the entire throttle map... does that mean they remove the restriction? Buggered if I know.
I asked them directly if they remove the restriction below 3000rpm and they replied "we do not", but they did state that they do remap the entire throttle map up to their normal 7100rpm (they will go higher, but issue a warning of "please consider engine safety").
I think your plan of the Gzone + emanage is almost as good as it gets.
came across this whilst searching ebay for other stuff.................... thoughts ???
Throttle Controller
Yes, a waste of money IMO. You'd be better off spending the $350 on real mods to improve the throttle response. Did you see the claim:
Enhances throttle response OR fuel saving of up to 20% ? I suppose 2% is 'up to 20%'....
Edited by Commsman
new o2 sensor today
was hoping to pull the pins out of the old plug and swap it over, turns out the neo plug has slightly smaller pins :(
3 crimp joiners later and i was away, i think the old sensor was ok but for ~$70 it should help on the way back up to qld
Installed my Walbro 250 pump in my M35 today and set up a power source direct from the battery to ensure full power to the pump at all times.
Reason for changing the pump was following the introduction of Nismo ECU, 3 inch suction pipe and spring on turbo actuator was seeing AFR being too high.
AFR's on medium throttle and below 4500rpm were all good and around 11.8-12.5 but higher rpm and more throttle saw AFR's is 13's.
So new pump fitted and now AFR's are much better at 10.7 to redline.
Now to start playing with boost again to see what the car will handle.
:rolleyes:
:rolleyes:
Hey Andy, that's a big change. Are the AFR's that rich throughout, or mainly heading towards redline?
Have to do a bit more testing to be sure but I don't think they were. Will be able to tell you more tomorrow.
Also got to get the boost controller working again and run more like 17psi.
Nice result & keen to hear what the AFRs are like after running around for a while. Mmm, more boost :thumbsup:
AFR's are
off boost low RPM (0-2500) 13.5 - 14.5
Low boost mid RPM (2500-4500, up to 10psi) 12.3-12.8
High boost full throttle (4500 +, 15psi) 10.7-11.2
Quite happy with these numbers.
Andy, those AFR numbers are pretty darn good. Off boost & mid range is very close to what I'm running. Upper end of rev range / max boost is a little rich compared to what I found works best for my car, so you have a nice buffer to increase boost safely.
Did you get a look at max injector duty cycle now?
I knew someone would ask that...... lol
It is certainly better than on the stock pump but at redline I am getting up to 95% duty cycle but this is with AFR of 10.5 so not too worried about that.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
