Not what I did to my stagea, but more what I did WITH it..
On the way to nightwars (a summer drag racing series), threw sparks all over everyone elses cars, popped a couple cats eyes out of the road and now all I can smell is hot metal... Flexi in the exhaust looks worse for wear and so does the rear tow hook... Might need to raise it. :(
Don't do it!:spank: As an extension to the "Don't buy wheels that fit the car; make the car fit the wheels" ethos; I propose a "Make the road suit your ride height" solution.
You just need to keep frequenting the roads you use; until you've worn a groove them all to suit your ride height, no more clearance issues.
Anything still grinding will eventually be worn away; consider these items "Surplus to requirement" Problem solved.:thumbsup:
You're welcome.:whistling:
Edited by Daleo
ok this is what i found............. so basically its a wait of money.
Posted 27 April 2011 - 02:24 PMsnapback.pngironpaw, on 27 April 2011 - 01:55 PM, said:
Anyreason these won't work for our cars?
http://www.importmon...%20NM35%2014750
review: http://my350z.com/fo...-installed.html
They will not remove our restriction.
Ask Scott when you see him next how well it worked in that regard.
snapback.pngbigkevracer, on 27 April 2011 - 02:13 PM, said:
If I read the old discussions properly though, Mines wouldn't remove the throttle restriction.
I figure we're not going to get a flash that does everything we want, but a flash that removes the speed limiter and throttle restriction and gives us 80-90% of what we want is fine with me. And when I want that remaining 10-20%, I can get an emanage knowing that the two main areas it can't fix are sorted from the flash.
Mines completely remap the entire throttle map... does that mean they remove the restriction? Buggered if I know.
I asked them directly if they remove the restriction below 3000rpm and they replied "we do not", but they did state that they do remap the entire throttle map up to their normal 7100rpm (they will go higher, but issue a warning of "please consider engine safety").
I think your plan of the Gzone + emanage is almost as good as it gets.
came across this whilst searching ebay for other stuff.................... thoughts ???
Throttle Controller
Yes, a waste of money IMO. You'd be better off spending the $350 on real mods to improve the throttle response. Did you see the claim:
Enhances throttle response OR fuel saving of up to 20% ? I suppose 2% is 'up to 20%'....
Edited by Commsman
new o2 sensor today
was hoping to pull the pins out of the old plug and swap it over, turns out the neo plug has slightly smaller pins :(
3 crimp joiners later and i was away, i think the old sensor was ok but for ~$70 it should help on the way back up to qld
Installed my Walbro 250 pump in my M35 today and set up a power source direct from the battery to ensure full power to the pump at all times.
Reason for changing the pump was following the introduction of Nismo ECU, 3 inch suction pipe and spring on turbo actuator was seeing AFR being too high.
AFR's on medium throttle and below 4500rpm were all good and around 11.8-12.5 but higher rpm and more throttle saw AFR's is 13's.
So new pump fitted and now AFR's are much better at 10.7 to redline.
Now to start playing with boost again to see what the car will handle.
:rolleyes:
:rolleyes:
Hey Andy, that's a big change. Are the AFR's that rich throughout, or mainly heading towards redline?
Have to do a bit more testing to be sure but I don't think they were. Will be able to tell you more tomorrow.
Also got to get the boost controller working again and run more like 17psi.
Nice result & keen to hear what the AFRs are like after running around for a while. Mmm, more boost :thumbsup:
AFR's are
off boost low RPM (0-2500) 13.5 - 14.5
Low boost mid RPM (2500-4500, up to 10psi) 12.3-12.8
High boost full throttle (4500 +, 15psi) 10.7-11.2
Quite happy with these numbers.
Andy, those AFR numbers are pretty darn good. Off boost & mid range is very close to what I'm running. Upper end of rev range / max boost is a little rich compared to what I found works best for my car, so you have a nice buffer to increase boost safely.
Did you get a look at max injector duty cycle now?
I knew someone would ask that...... lol
It is certainly better than on the stock pump but at redline I am getting up to 95% duty cycle but this is with AFR of 10.5 so not too worried about that.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
