i didnt know your turbo was on the way out leon, damn!
dont bother with new arms, just replace the bushes. unless you want stock bushings, then i have a pair of arms :P
Yeah, I was hoping it would hang around a bit longer. I think if I didn't play around with it (read add boost etc), it'd still be going ok.
In the end I couldn't drive it without plumes of white smoke every time I lifted off. Funny, the cars got 99,xxx km's, and everyone said to factor in a turbo change at 100k, lol. Was planning to prove everyone wrong, but couldn't help myself - had to push it....
I have new bushes on the way courtesy of Dale. Arms look straight, just not located in right place.
Are you still going Hypergear rebuild Leon?
Did my final prep for the SAUSA track day today - replaced the oil and filter, fitted a power steering cooler and replaced the fluid.
Also noticed that I've got a set of semi slicks on the car - once the car was up on the hoist noticed the rears are almost on the tread bars, so will be replacing shortly.
Couple of things do to now, replace the drivers side inner CV boot and replace tyres (and upgrade to 18" wheels), before I get back to upgrades.
Well i have definitely proven everyone wrong. 305,000 klm's - stock turbo.
Ever since i got it @ 132,XXXklm's (previous owner did not rebuild the turbo), I put it straight to 12psi.
I have always done 10,000k oil/filter changes (motul 8100 excess / ryco filter) and i always make sure my last 5minutes of driving are tame and to leave the turbo timer running for 1 minute.
Seeing as my turbo is that ceramic/nylon mixture I am quite surprised. I bet i have now jinxed myself and tomorrow it will die...
Edited by Jezboosted
Yeah Ryan, Hypergear rebuild like sky^rkt, but not as wild as his. I hear he's aiming for a big number from the stock housing. Will be interesting to hear how it drives when finished. Mine should be almost as responsive as the stock one, but with a bit more puff up top & no puff out the exhaust, I hope.
Let us know how your track day turns out. Sounds like fun.
So I've modified and painted a Dayz bar.
Plastic Dayz bar with some previous damage. I removed the centre number plate bracket and recess the number plate in the front cover and painted it up. Came up ok but I rushed the colour coat and got some crap in it. Will have ot come off the car again to be fixed.
The bar when I fitted up the cooler.
Final mock up before glassing.
Progress and final before paint prep.
Painted and fitted
SAUSA track day today at Mallala.
First session was shit. Two offs, one due to tyres through turn two, and one when the Trans wouldn't shift down.
from there on it was awesome. Car was relatively trouble free, despite the shitty tyres. Brakes were awesome, but front wheels were covered in dust, rears clean.
Only real issue was the Trans. By the end of the day the 'manual' mode wouldn't shift down at all, but it was fine in Drive. I'm guessing shift kit and Trans cooler will fix this? Anyone with one, does it actually shift when you tell it?
I also had issues with the shitty GPS timing app I was using. Best time it recorded was 1:36.5, which doesn't seem too bad for a first attempt.
Tyres, shift kit and F-con before next time!
Not really, it wont kick down unless you are going slow enough, buggered if I know why as it will kick down when you least expect it on its own.
The shift kit makes the gear changes firmer but the stock ecu still backs out all the timing between gears. Fcon will fix that though. ;)
Turbo is out finally. Thanks to Scotty & Jetwreck for their occasional pearls of wisdom. Hypergear one hasn't shown up yet. Hopefully tomorrow so I can staert putting it together before I forget where eveything goes.
I can't believe there are people who do this more than once!
No problem Leon, not a job I would recommend people do themselves as you found out. lol. Just hope the mani studs stay tight on yours, Ive had a few come loose now without those copper coated nuts holding them tight. If not you will get the dreaded gasket squeal and have to do the job again. :no:
when they get sprayed and the rear wing and other bits are on the car I will post up pics of my NM35 N250R WB LM!
Received my F Con Harness today ;)
Also bought a bonnet today :whistling: Would probably look good on your car Craig....and it is already black!!!
Bastard!.....it would look good!!!! Would....lol!
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
