I replaced my castor bushings with superpro ones. When getting an alignment done, the castor was slightly different between the wheels but it hasn't proven to be a big deal. However if I were to replace the bushes again I would have just bought adjustable arms.
That must make it Adelaide cruise time! There are a few people keen for a Feb cruise.
I did really exciting things to my car: I retuned the throttle. *YAWN* Feels better though.
Omg a m35 has new wheels def time for a adelaide cruise lmao
Nah they look good dunc cant wait to see them on .
But all jokes aside def time for a adelaide cruise
Considering he's had the car off the road for months and missed a years worth of cruises, I think it's warranted.
Lol i love stirring 35 boys up always get a bite, hey my car was off the road for 9 mths came back on with engine transplant 19" wheels an 340kw. So hell yeah lets cruise lol its warranted lol.
This :) (yes my car needs a clean, and yes its black, Haven't looked for a matching grey paint yet).
I run one of these on my head unit.
Micro SD to USB adaptor.
So neat and out of the way. Less likely to knock it and bust your usb input port. It barely sticks out lol.
Neat job you did on the gauge intstall and surround.
I received a red and yellow box today with the same two letters repeated. Wating on another box to arrive with HKB on it.
Thanks guys :)
Yeah made it up, was quite a bit of work.
Just a few pics from the weekends work;
@Jezboosted Thats handy :) I'm going to a difference system all together so no more of this front usb crap I can't stand it getting it the way of my cup holders when i throw a maccas cup in there haha.
Edited by WgnZilla
Spent 3 hours with a red sharpie permanent marker fixing the sun-bleached red stitching because my car has spent soooooo much time sitting in the sun at my mech having work done. That, and the fact that I only have a carport available until my under-house 4 car spots are ready...
On a brighter not, my internals arrived on Monday and went straight to the machine shop, where my block is waiting: hopefully I'll be looking at an almost complete engine in the next week, then it's being on the run-in week of driving pleasure!!
Destroyed a new $1600 clutch at willowbank last night! Whatever holds the throw out bearing in the pressure plate (pull type clutch) decided to fail
So started the process of pulling out the box, had to cut the front drive shaft bolts with a grinder because a un named favorite business on here who fitted the clutch rounded the nuts off.
Edited by GTR260
took out the gauge cluster out of the m35 (volts boost torque) removed the boost and installed a 30psi autometer one in its place. works a treat and for the first time since scotty did all the mods i know how much boost its running hahah
get a hdi EBC with digital gauge.
Craig had nothing but problems with his HDI and I am now of the opinion a good mechanical option is best. He already has my HD actuator fitted, and the manual bleeder is a solid performer. No need for the defectable electronic options imo, even though they allow slightly better response. (due to the little spike they give.)
Although, some EBC's have an overboost warning, this is more important than a boost gauge I feel.
+1
No difference in performance between the hdi and turbosmart T.....Ive been swapping between tge 2 for weeks.
The only really difference is the hdi spikes like a mofo and the T maintains control.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
