Haha okay cheers scotty well in the mean time it all seems to be going well *touches wood* I'm not after massive power, I play with plenty at work, just wanting reliability/no issues with the mods i've got.
Anyone live near blacktown and want to be my plan c?
trying to grab a bargain and i'll be coming through sydney in about 10 days
so if either of my two friends can't get to it who would want to pick up some suspension for me and pay for it (its retardedly cheap at $100) and i'll give you the money when i come down plus something for your troubles
hey tom, im near blacktown so any problems send a pm or if goldzilla cant do the pick up. :action-smiley-069:
Ok suspension is now in my friends possession, misread the add so instead of $100 it was $200 but the guy gave them to me for $175
So now i have a full set of Bilsteins (to suit gtr, so not 100% ideal but i can deal with it) with king springs (not perfect but...)
Plan is:
Get shocks from friend
Drive to TAS
Source some strut tops (only thing missing from the shocks as the mechanic who installed the guys coilovers took them off for some reason)
Create a set of shocks with Eibach springs (currently on the car) and Bilsein shocks
and another set with my Impul shocks and the King springs
Set Bilsteins to lowest setting
Win at life (hopefully)
Also, the Bilsteins are yellow to match my car :)
So anyone with some applicable strut tops, sell them to me please
edit: attaching pics
Edited by pipster11
Plan is:
Drive to TAS
You going to get them serviced before putting them in? I loved my bilstein setup with Nismo springs.....was awesome!
Nice win btw!
Nice win btw!
Yeah pretty stoked at the moment, how much does getting them serviced cost?
I cannot recall exactly...your in tassie aren't you?
Edited by Jetwreck
Unfortunately the tops will be missing for a reason. Many suspensions sets don't come with tops and you have to reuse the existing ones.
So if you are swapping your standard ones over just reuse the tops from those. If you don't have the standard ones....they are very hard to find because everyone needs them! Sometimes the easiest way to get a set is to buy some second hand standard shocks just for the tops :(
Put some tyres on my 18's as I was running stockies.....changed those over then installed my system alpine splits and tweeters with a alpine amp also hooked up my spare cadence sub and mono block.... Also washed it lol.....
I actually asked fatz on fb and he has some!
Any chance of an r31/states owner combo super mighty lowball fatz?
Edited by pipster11
Installed and set up my shiny new boost controller
Will need to change my spark plugs now I think, feels like spark is sometimes breaking down between 3-4k rpm, think its because my current plugs are gapped at 1.1mm
