Gave mine a quick service with some GW Synx 3000 and a new Ryco Platinum filter
Pretty interested to see how it goes, has to be changed after 5,000 kms according to the packaging
got the stagea back today from the tune on 98ron
very happy with the result and drives very well feels extremely smooth trent did a fantastic job
doesnt look very smooth according to the curve........ nice Kw's though :)
what motor and turbo is that ?
Installed and set up my shiny new boost controller
Will need to change my spark plugs now I think, feels like spark is sometimes breaking down between 3-4k rpm, think its because my current plugs are gapped at 1.1mm
exactly the same as mine, location and same controller
Turbo off, 044 and surge tank fitted, need to do lines, wiring done, ev14 injectors wired up, getting somewhere now.
Car has new exhaust studs...sweet..but all the bolts where loose(undone with fingers..lol), and turbo side hose clamps where loose..boost leaks galore
no wonder it never went anywhere..lol
trialed scottys inlet pipe, looks like it fits well atm
cheers
darren
yeh oin the dyno graph there is a drop but it drives great i cant complain feels heaps better just in day to day driving. thanks scott yeh trent was hesitant but happy with the results. thanks heaps for everything u did to the car ever since u did it all it hasnt missed a beat thanks again
hey sonny do you notice the difference ? I have r32 gtr all round on mine stops well.
Hi Rudi, yes big difference compare with the standard single pot calipers. Rears are standard atmo.
Fitted touch screen head unit, BC Coilovers (fitting thread on here helped get rough heights), 19's inch wheels and Highflow cat and 3 inch custom exhaust to my new M35 in the last 2 weeks :)
Got a greddy turbo timer and greddy boost gauge to go in soon.
Beau, don't bother with the turbo timer, they aren't required with water cooled turbo's. (even tracking them). Your insurance company won't cover it if stolen due to fitting an immobilizer defeating device either.
Just gave it a vacuum after going to a 3 day music festival a few weeks back and my effing gd was it filthy. Think it needs a full detail by a proffesional to get it back to how it was.
Ahh cheers for that mate. Just the Greddy boost gauge to go in.
I have wanted to change the factory cluster to white and found a Aussie company that will make a custom one for $75... they just need an M35 one for a template. If I could spare mine for a week or so I would but until public transport in the south of Adelaide goes back to normal I doubt i could go a full week without my car :(
I have a spare here... Perhaps they could get the speedo dial more accurate too?
Not sure. I enquired if they could make me up a simple custom white face cluster and as they haven't done an NM35 before they said that as it will be a new product to their range they won't slog me full cost (as this will benifit them also)
I'll forward you their details if you like. I'm not sure of the quality but these mods are simply cosmetic anyway
Fold down seats - check
Fill full of crap - check
Head south - check
Just stopping in Grafton tonight at my mates place, then on to Canberra tmrw via a couple of stops in Sydney tmrw
Then Canberra to Melbourne on tuesday and onto the boat tuesday night
Getting back into Launceston Wednesday morning
Obligatory packed up car photo:
*Insert NISMO 280km dash here
I already have one, but it is damn useless as it is way out. I would prefer to have a 180kph dash with accuracy.
I would like the triple gauges white too if they can do it...
I have one here mate, can take it into the city if you can pick up from there?
I swear the Nismo dash is more accurate. Not accurate, just more accurate than the stock POS. Although I think revs are slightly out too...
let me get back to the company and i'll let you know mate.
Nismo would be great but $400 odd dollars
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
