The cam tensioners take a fair while to fill with pressure once re-assembled, that would have been the noise you heard. Nothing to worry about unless it doesn't go away. The workshop manual says to rev it to 3k and hold it for 5 minutes to bleed the tensioners. The valve gear has solid buckets, some are shimmed and some aren't.
If it's hard to start, try a new battery first. If you still have issues, is there an engine light up? Most of the faults will throw a code.
This sounds like it might be the cause. i've just noticed that i've got a slight oil leak so am having to track that first and sort it out. found one of the 22 bolts for the front cover one wasnt tightened all the way. so will re check them all again and clean it up hopefully sort that out. and then bleed the tensioners cause 3k for 5 min with a oil leak might not be a good idea.
as for the battery when i connect up a jumper pack i still have the same issue. but jumper leads to a vehicle the issue is still there just not as bad.
there was a timing fault that came back before the chain but thought that was cause of the chain needing replacement. might be a good idea to run a diagnostic again?
clearing the ecu faults and cleaning and the throttle re-learning procedure probably wouldn't hurt too
thanks for all the help. have read that sometimes the passengers cas fault code doesnt come up sometimes?
also how many liters of oil does a engine normally take?
EDIT: sorry done a google search and it lead me back to SAU with the figure 5lts.
Edited by projects
Also i'm now having a starting issue which i thought the timing was out from the chain, but with that replaced its still hard to start. I'm wondering if its a faulty sensor or if the starter and everything is drawing to much current from a slightly old battery. Would the ecu or learnt that with the old chain and timing been so far out to drive like that. and now its back to factory it cannot start properly?
Hi and welcome to the forum. Have you looked at the intake & plenum for carbon build up? Apparently this is a bit of an issue on the non-turbo stageas due to the direct injection, there was a thread on the v35 section of this site with pictures that showed significant build up after far less KMs than are on yours. I seem to remember someone cleaning it and finding that the car ran a lot smoother and also started on the first crank. Probably worth checking out.
Dale spec front brace.
All I can say is WTFBBQHKS.... combined with swaybars and the bushes the car has awoken. turns in soo sharply.
Imagine all the hard parking I can do now xD.
Make a very nice difference aye!!!
Well this months budget thanks to Jetwreck is ruined., he is a bad influence haha. But I would be 100% to grab one 15th of next month once I'm paid again
So not a massive rush but would love one then
Edited by Brick
Ha, it's wet today and I have to pick my GF from the airport so ganna be super fun!
Everything adds up. All I need now are my shocks and spring and wrap mah rims in some decent rubber and I'll be glued.
HA! yea he can easily spend all your money! But he's also good at saving you money. I wanted to buy a whole set of bushes he talked me out of it and said just buy caster ones and I'll be sweet. Saved probably $200? Or more.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
