Well thanks for jet r31 getting me off my butt and giving me a hand, I've nearly finished hooking up my water/meth injection, then it's tune time again see what happens :) cheers brother . Also I fitted up my rear brake conversion and front adjustable camber and radius rod arms and chucked in a set of new tie rod ends and a afr gauge to go with the rest of the info in my cockpit
Ready for the cruise? Or you taking the daily?
Had my drivers side front wheel bearing replaced this morning; nice & quiet again.
Not doing it myself was the best $160 I've spent this week.
God I'm lazy. :woot:
Edited by Daleo
  • Like 1
You are lazy! Easy job is easy!
Just got back from the retune.
Car now runs on the MAP sensor. MUCH MUCH MUCH more responsive, but no more power. Apparently 200kW on a Dyno Dynamics now, but no print out.
The weird thing is it's running Scotty's modded actuator and only running 9psi at the top - so it's 2psi more than last time with the stock actuator.
Got to get this boost sorted, and find out why it seems to be speed limiting still.
Much better package though, and much happier. Just want my farkin boosts!
9psi? it sounds like you have a leak in the vac line, or yours is the only turbo not holding boost.
Did your turbo have a larger wastegate puck or something?
Perhaps the actuator doesn't have enough preload?
Check this. You need about 3mm of the width of the hole on the actuator for preload imo.
Bigkev ,no print out I would be asking "demanding a print out " it's an important reference to your car it's no good having all the bells and whistles and not having a guide to what it's doing and be a grumpy man if I was you
^ This. Just what the hell are they doing Ryan? You'd think for a shop with such a reputable name, they'd be a bit more helpful... or is it because you don't have an R35?
I think he's had someone else look at it..? or run it elsewhere. Dunno who has an AWD Dyno Dynamics unit off the top of my head!
Ryan, check out Theo's boost drop. He's stock turbo too, I suspect it's all about running out of compressor flow.
http://www.skylinesaustralia.com/forums/topic/357886-lambchop-with-a-renault-axis-here/?p=6493662
When I had my stock turbo it would hold at least 13psi to redline. No doubt it does run out of flow, but 9psi sounds too low.
How is boost control being done Ryan?
Thanks guys. I'll try and tick everything off...
I've replaced every vac line now I think. I can't see how that would be it.
Stock turbo, stock wastegate puck. Andrew at AM wants to bore out the wastegate 1mm but nothing has been done yet.
Actuator is your modified one, exactly how you sent it to me. If it needs more preload do I just put a stronger spring on?
Which hole Craig?
Thanks guys. No printout, it was supposed to just be a fix session and the map ended up being redone. I could have asked for the printout. I didn't. I'd just sat in the passenger seat and seen the whole thing so didn't think to ask.
Mine was similar to that (although wtf is that at the end of the drop off?!). I wouldn't have thought it was running out of compressor flow that early? I thought others had more success on the stock turbo. Funny that Theo and I have both changed the vac hoses, and both get similar graphs.
Scotty's modded actuator with the HKS EVC.
9psi is the boost I used to get when my boost solenoid would stick open. Sounds like the wastgate is fully opening.
Weird thing is, it was 7psi without the modded actuator, 9psi with.
I want to see if I can find the boost problem, fix it, then take it to somewhere else to get the EVC setup properly and the tune checked.
For the record, the original tuner (who I won't name on here but some people know) once I explained all the issues offered to fix it, ended up retuning on MAP instead of AFM at my request, and spent near enough to two hours with me explaining things and talking about it. So far it seems like they have fixed it and improved it no end, but at the request of a few people I'll get it checked out just for peace of mind.
My actuator has almost 5mm of preload, the stroke of the thing is huge.
The hole Craig is talking about is the hole in the Wastegate arm, that the pivot pin goes through.
Boring out the Wastegate isn't going to make it hold boost better, if anything; it will allow you to bleed boost pressure more easily.
It would be worth doing if you were building boost pressure uncontrollably, but you have the exact opposite issue.
What's stock? From memory 3mm isn't it? And I didn't think Scotty modified that hole. Should I drill it out to 5mm?
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
