Aluminum would do the trick
I'm on board if Scotty is keen enough to knock a nice looking one up!!!!
I enquired about the ones on ebay
INFINITI G35 - RARE JDM POLISHED ALUMINUM LOWER ENGINE COVER UNDER PANEL TRAY
http://www.ebay.com/itm/271241580470?item=271241580470&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
For this one they want $420 for shipping through UPS and of course cannot guarantee fitment or at least a bit of chopping and changing would be required.
Infiniti G35 Aluminum Engine Splash Shield Under Tray Cover Black Powder Coated
http://www.ebay.com/itm/151074592895?item=151074592895&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
Also fitment cannot be guaranteed and would require chopping as G35 has a different width bumper to that of a Stagea
Can't remember who was asking for the stagea manual
but i put it up on dropbox
https://dl.dropboxusercontent.com/u/36164620/Stagea%20Service%20Manual.pdf
Let me know if it doesn't work! (give it a few hours as its still uploading tho)
The second link seller has a separate item for the G35X, http://www.ebay.com/itm/Infiniti-G35X-Brushed-Aluminum-Engine-Splash-Shield-Under-Tray-Cover-Aero-Shroud-/151090681557?pt=Motors_Car_Truck_Parts_Accessories&hash=item232db4d6d5. I would assume these would be closer fit as I've noticed that on my plastic under tray is has AWD stamped on it.
fitted nismo dash... next will be HDI intercooler however when my kit arrived last Friday the core had been damage (5 badly bent fins and 1 tube damaged)
So that will have to wait.
My intention was to clean and detail my car. Instead I.
Saturday - cleaned up wiring behind the dash. Found that who ever installed the mongoose m40 immobiliser have left exposed wires everywhere and they were all tangled. So shrink wrapped all the exposed wires. Cut and untangled the rest of them and secured the box unit. Also installed the switch for the dvb tv so kids can watch it on long trips.
Sunday - cleaned up and secured all tv tuner wiring in the rear of the car. Relocated the infared receiver to infront of clock display. Found where the reverse light wire is (red with silver stripe) and ran wire to the front of car for when I do the brake mod. Just confused with what wire it was to cut (pin 55 - red with yellow strip that says its for lamp signal, pin 59 - pink with blue strip that says its for brake signal).
Doesn't work
Well i was thinking later on (after the motor swap is done) of getting a sedan one and altering it to fit the stagea nose and if that goes to plan just have them locally made?
But like the with the sedan ones there are different ones for AWD and 2WD models. So there are going to have to be ones made for the NM35 stageas and the muran...i mean PM35 stageas (im looking at you alex)
  • Like 1
Bloke? You mean Cam? Pfft. His was barely modified... As stock I agree the series two is a little better, other than the glass motor. :P
should be better.......in every aspect! It's newer for a start and it's as series 2. Pity Nissan went backwards with the power big time and economy a little!
Have to admit the last time I drove a Murano it felt about the same as a PNM35......just a little slower off the line.
Undertray part number (straight out of FAST) 75892-AL800 - superseded by 75892-AL80A
Sept 01 - Jan 03 - V35 (AWD)
Aug 04 - Feb 07 - PNM35 (250RX Four & 350RX Four)
Haha, yeah but both unmodified and lightly modified I can confirm that the series 2 is a far superior car.
Only thing the series one has over it is power... but if you go into heavy modified versions of each, I would suspect that the series 2 would have it all over the series 1 there as well.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
