Now your talking scotty one set for street and the other for track ;). Just dont tell the missus!!
I was still surprised as they pulled me up pretty well for most of the 3 laps just had to brake alittle earlier as i wasnt super confident with them and im no expert on the track as it was my first time at a real track.. Good day out and surprised a shit load of people as im the loan wolf at the moment in tuned stags over here.
Replaced shocks all round, and bled the callipers since i was there.
Also - HPX are hopeless for track work. I know two people who tried tand both were miserable failures.... A1RMs are a whole different story, but i would expect they would be tough on rotors if you used them for street. Cold bite is not great either, so agree that pads are the #1 thing to swap in and out for track days (or maybe #2 after tyres).
I've actually heard that if used hot they are good on rotors
Street work (cold) is what kills the rotors with the ar1m's
18 x 9.5 +22 Volk Rays Gram Lights 57DR in black
235/35/18 Federal 595 RSR's
GK Tech V2 adjustable Rear Camber & Toe Arms
'93 R32 GTR Pull type gearbox
Extreme cushion button clutch (installed by Kidafa, thanks kid!)
Nismo GT Gear Knob
Greddy Informometer
Pioneer DEX-P99RS
JL Audio C5 6.5" Splits
Series 3 R33 GT-R seats
Greddy catch can w/ speedflow lines & fittings
Setrab oil cooler w/ speedflow lines & fittings
New Nissan Thermostat
Radiator flushed
AM Performance low mount manifold
AM Performance split dump
Garrett GT3076R w/ speedflow lines & fittings
Tial 44mm external Wastegate
Splitfires
Deatschwerk 1000cc injectors
Walbro e85 fuel pump
E85 tune
Ran 290rwkw on the heartbreaker dyno...
Now more serious, new build 50% complete:
Tomei Rods
Tomei Pistons
Tomei Oil Pump
Tomei Sump Baffle
N1 Water Pump
Ross Harmonic Balancer
Deck Shaved
Head fully reco'd
Oil control mods
Supertech Valve Springs and Titanium Retainers
Tomei 256 Poncams
ID1000 injectors with fuel rail and Turbosmart ext. Fuel pressure regulator
Still e85 of course :D
I think that's it, I'll update with the dyno sheet when it's all done... :)
Excellent ! Well done what psi you running , sounds like time for some photos to come up, and start sourcing a rs4s rear cradle ;) axles go snap soon
I'll be aiming for over 20 once the build is finished, I'm guessing 22ish, or wherever the 3076r runs out of efficiency really. I'm hoping it will be finished in 5 weeks, still waiting on the jun extended crank collar for the Tomei pump. Pistons/rods are going in as we speak and I'm pretty sure the head will be finished by now... I'm going in to check on progress next week when I get home, I'll take some pictures and report back then :)
At what power level do the rear axles become questionable?
Impressive specifications! (should have got the crank collar from me though...ahem). I guess you will be looking for around 350awkw? Your skinny tyres (would be illegal over here) might save you but I would be looking to upgrade especially if you are going to drag it.
What brand is the rad; looks huge! I take it that it sits a bit too far back to fit the shroud?
Im not sure what brand it is but its 3 times as thick as the old one! had to get one hacked up to fit in, yep fan just clears the rad by about and inch or so
very nice suction pipe!
P.S. Without the fan shroud I suggest you do some shielding in front of the pod to get rid of the hot air.....remember the heat sensor is in our AFM and it will affect your power through traffic.
Thanks its a bit of mix of scottys one, the shielding sounds like a good idea ill look into it at some stage
He he, I didn't even know you sold them :P I got the jun one through Jesse, it cost around aud$100 so I was happy with that :)
The federal 595rsrs are known to fit wider, more like 245... but if I have to upgrade then so be it :D I'll probably have to look out for one now...
I'd be happy with anything over 330wkw really, I'm not that crazy for power and not yet willing to upgrade the turbo again so we'll just max out the 3076 and I'll be happy... for now :)
235/35/18 Federals on 18x9.5 +22 gram lights :)
Very nice :)
My axles held up well on the street but first second they saw a the track with vht on it snap!!! Just finished putting in rs4s rear cradle with a 2way in it . 350 is a good aim After that your leaning hard on the drive line but not so bad in an auto , was going to pushy old girl a fair bit harder put the built motor in do a dog box change turbo push towards high 400s ,basically it's like starting again lol . But I thought I've already reached my set goal and haven't turned boost up yet or my wmi on . So might buy another toy instead ;)
What size rear you running on 3076r
Scotty do you think I should change pads for track work or will the stock akebono's pads be suffice ?
It depends how much you lean on the brakes, and how hot they get. I would assume you would need A1RM's at a minimum.
Very nice :)
Very nice :)
It's a 0.82 rear. There are a few little things left to do to it, but like you I don't feel the need to spend much more from here :)
57DR in the box...
What's the response like with the .82 I would like to compare with mine out of interest :)
I'll get the dyno sheet and post it up when I'm home, I didn't drive it in that iteration of the build :)
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
