BTW, my HPX pads and DBA rotor combo squeals quite badly. I'm guessing this will settle down eventually?
Also, where can I get a centre badge for the steering wheel, any ideas? It's still got the S15 "S" in the middle.
We have HPX in our daily; the bed in is critical. They seem very susceptible to overheating during bed in; this draws the pad bonding materials to the face of the pad.
All of it was done without going over 60km/h, 10 stops down to 10km/h; no squeaking or squealing.
People think because they're a quasi "performance" pad, that they need to be bedded in at 4 billion km/h and until fire is pouring out through the spokes of the rims.
If they've been overheated in bed-in, they may bed salvageable; but they may not be.
Chamfering the pads may help, as may lubing shims, etc.
The combination of HPX pads & DBA rotors seems to present this issue more often than other combos, but I don't think it is an incompatibility issue per se.
Just got my Stag back from the mechanics after not having it for almost just over 3 weeks. :lol:
Four welch plugs replaced
Turbo swapped to one I provided - stock V45 (old one had a mad squeel and it couldn't have lasted too much longer)
Cam seals
Crank seals
Clutch slave + lines
Some block oil seals that were leaking apparently
Flushes and liquids
But have you made that decision without actually trying it first? I'm guessing you have. While I'll agree that steam cleaning bustier carpets can damage the pile, using a steam cleaner on crotchless carpets can invigorate the weave and provide a pleasant warming sensation. They don't call it a Rug Doctor for nothing you know.
Edited by Hertz Donut
I got my stag 'beached as' yesterday. The driveway at my new place has a ridiculous hump at the start, and I wanted to make sure I would make it over it...
Turns out NOPE! Haha.
So it looks like I will be raising the height an inch or so... Damn... Lol!
I'd just cut up the driveway!!! or buy a new house!!!
Haha! I would definitely redo the driveway if owned the place, but unfortunately just renting... :(
Yeah the two wheel deal happens a lot also... Seriously need to have stern talking to who ever design these driveways... Haha!
Hmm, well I don't think squeal settles, only gets worse in my experience.
Obviously the guys re installed all the shims and things, maybe go through the bedding procedure again, and see what happens. Mechanics tend to be a little fast in the bedding and don't do it properly. If still bad, rip the pads out, clean, reassemble with gunk, and maybe file the pads.
My HPX are perfect on the stagea.
I hope not.
I'm going to check with them, but I'm assuming that the shims went back in.
Still got a Cat in the exhaust?
Yep, it's still there. It has been modified a bit, but not enough to run the risk of a $10k fine from the EPA. Apparently even the best Cats show restrictions, despite what they're supposed to achieve with their advertised flow rates.
Well, last night (Friday) I went out for a feed, then took it for a bit of a drive and on the way home I went into a quiet, flat part of the industrial area near home and did some bed-in from roughly 50km/h to 10km/h with a fair bit of pressure, and it helped a fair bit. I did about 7 stops, harder than I normally brake, but not nearly anywhere hard enough to trigger ABS.
When I go for another drive, I'll know for sure. Either way, I have to go back to Unigroup to give feedback on how it's all going, and in case anything needs tweaking, so I'll have a chance to ask about the shims and the brake goo.
got a replacement headlight for my condensation filled passenger light.
gave it a good clean....mmmm
from
to
sick of the stag looking like it has a black eye.
also test fitting eyelids...which i cant seem to get to fit quite right.
brought a heap of stuff for the old girl of ebay this morning, got cargo net, nismo springs, rear light to replaced the scratched one, hicus bar, roof racks (will help with moving all the stuff)
It apparently has protectant in it so we shall see how long it lasts.
I've used the same stuff and used all of the sealant on both headlights and now after about 5 months they're starting to yellow again. Probably need to source some more sealer from somewhere...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
