I miss the stock turbo's response sometimes. On the other hand the engine now gets run through a larger rpm range, for better or worse. I could basically run the car under 3000rpm all the time. The hi flow is very much on light duty for what is essentially a stock replacement.
Urgently needed some pads for my 330mm D2 brakes and fitted some unknown street pads - lasted just one track day at Hampton Downs! Will go to Race Brakes and get something better...
Racebrakes sold me some Pagid pads which I will fit now and then take the old pads to them for a street lining which I will then put in the car and save the Pagids for track days.
Had a smoke test done on my car today to confirm why it's making a strange hissing sound from the intake side when on boost, and confirmed that the gasket between the top and bottom halves of the intake plenum is leaking. Hopefully once this is sorted, it will also reveal why my power and torque curves flatline at around 5,400rpm and max out at 235rwkW. Should be capable of at least another 30kW with the latest round of mods.
The proper (Turbosmart style) ball valves actually work in a similar way as the electronic controller, and they do a great job of holding boost pressure off the actuator until the desired boost is reached.
I still prefer an electronic controller for the simple fact they have an overboost warning, and the ability to run a 4 or 5 port MAC valve.
Looks good Toby. :)
Thanks Scott
your help and being available to discuss any entry level issues have allowed for a direct and proven modification pathway.this stops money been thrown away several times on the R & D rollacoaster of fortune or fail...
P.S attempting to knock over as many mods at home here so hopefully theres less time spent on your hoist and whilst At your performance Garage.
Looks good Toby. :)
Thanks Scott
Maybe then I can bring the whip and junior along to.
Edited by TM35
I'm not sure this should be in the 'what have you done to your stagea lately' rather than 'what will you be doing to your stagea soon' but I'd prefer not to start a new thread.
n00b alert
Quick question - I've warped my front rotars and will be getting new calipers at the same time. I'm about to get my hands on RDA slotted front rotors 296mm by 30mm for my nm35 - the seller is saying they suit R34 GT-T but I beleive the GT-T came out with 310mm by 30mm and the R34 GT came out with the 296mm.
Should I be asking the wreckers for front GT-T calipers or GT calipers. My knowledge of brake system is zilch to none.
Years ago when I used to come on here, I think I remember people buying the V35 Skyline GT cat-back exhausts as a cheap direct replacement for the NM35s big heavy resonator. Am I remembering correctly? what about the 350z exhaust - that also works but needs a minor mod?
Edited by Drogba
I think you are correct James, it's the larger disks you will need. Best to ring GSL rallysport, they know their brakes backwards.
I have a decent cat back here atm... How loud are you wanting though?
Just sent back front set of RDA brand 296mm (doah!) to change for the correct 310mm to suit a 2nd hand set of R34 GTT callipers ive purchased threw just jap after they measured up to a front cut NM35 they had sitting there apparently straight boltup.RDA Dimple drilled & slotted items via ebay also were a very competitive priced for brand new, a new set of Intima SR street/circuit rated pads will bite into them.
Cheers, okay got my hands on some RDA 310s now. How much were GTT Calipers from justjap?
I paid $320 inc. freight to adelaide.
Im not sure how many sets they had but otherwise i recall gumtree had a front & rear package advertised.
my painter mate used the good weather oportunity to resray my front bar and cleaned it up. looks much clearner without the scrapes and wear.
also managed to get my tires fitted to the new wheels ready for the "lets make them fit" game.
happy with the amount of stretch
Edited by GH05T
The V35 coupe mid pipe is a direct replacement for the Stagea one...
The 350Z one is basically the same but shorter, efectively by the straight bit fitted to the engine end of the V35 coupe one..
Mine was $120 from Niss4x4, and took about 20 minutes to fit. 2 months later took another 10 minutes to remove the brace thing on the tranmission tunnel, prop shaft catcher thing, as the exhaust was hitting it..
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
