My M35 on the hoist....
Slowly working through the problems of adding 6sp RWD box from a 350z :P
(which means i'll have a transgo fitted auto box for sale shortly)
Edited by Beregron
  • Like 3
I wired up my aircon fan so that it blows instead of sucks. Amazing what correct airflow does on a warm day...
Also sorted my AWD issue; many thanks to Scotty for his help in sending me bits I thought I needed, but didn't.
Not my best week with electrical work this week...
  • Like 2
Love me some hoverstag action. :wub:
Dale what was the issue with the AWD in the end ?
aircon fan was originally behind condenser?
It's great seeing progress.
Still issues to overcome and i'm hoping as everything comes together others might have some progress on their tuning endeavours
  • Like 1
My stupidity apparently. :spank:
I had Scotty send me an Attessa main relay, as I believed everything else was ok.
After fitting it with no change; I then moved down the line to check for continuity at the fusible link, and discovered this;
12064414_10153697918882392_1014231804_n.
FYI; the centre pins are the 30A fusible link for the Attessa ETS. The 50A is the BCM fusible link.
I'd checked this link before visually and was sure that it was ok; but I think the burned piece of the link must've just been sitting inside the connector; looking sneaky.
When I popped the lid off to poke the multimeter probes in; my stupidity was revealed...
​Found the part on EPCdata, was quoted $35 each from Nissan Aust, so I'm going to grab a few online for $11ish (free delivery).
Poked in new fusible link; no AWD light and pumpy noises. Happy days.
Damn; I should've been a hand model...
  • Like 1
Nah, I fitted an HDi intercooler kit for my tune a month or so ago, and fitted a thinner fan to suit; was SURE I had it going the right way.
In traffic once the weather warmed up; the car seemed to be running hotter than I remember. Once moving; the temp would drop into the low 80's, high 70's; like normal.
Sure enough; it was throwing hot air out through the grille; so I just had to pop the pins out of my connector, and switched them around; back to normal.
Like I said; not a good week for me with electrical stuffz...
  • Like 1
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
