Not really worth the cost with other options out there but each to their own.
Yes, If money is your concern then this build really isn't for you.
Went for a decent drive then down the freeway around a few open roads. lots of change of speeds from 60 to 110+... very happy with how this has turned out.
Edited by Beregron
Money is always going to come into play with any conversion/modification.
But the way that i see it is that we are all on the hunt for more power or performance, if we weren't then we would leave it stock. I'm happy for someone to correct me, but by doing this conversion, replacing the auto transmission to a manual, and going RWD, you will end up with less power loss through the transmission and in theory you will be getting better wheel KW than before without touching the motor. Especially down low when you are cruising around town where the majority of the power is used day to day.
Yes it may be expensive, but I have seen people spending huge amount of dollars for small power gains.
Edited by DrLui
Some people have half of that value tied up in just a turbo changeover...
It's all relative.
Good on you Beau; go your own way mate, I bet it's going to be awesome.
  • Like 4
Good stuff Beau, thanks to you and your mech for the read! :thumbsup:
Yeah no dramas at all.
If this can help people then that's what it's all about. I know i'm going to enjoy it :)
These kind of write ups are needed more. Most places dont like doing this to have the work come to them. They dont realise that even though they have written up, owners are still going to go to them knowing that owners will get what they want. Unlike a tuning shop in qld that hides all from potential customers.
  • Like 2
Thank you Beau for sharing our link :) We are hoping our guide/parts list will help the next person/workshop wanting to do this conversion.
We did the write up as it was occasionally frustrating throughout the build having very little information. We wanted to keep Beau's bill to a minimum and not buy a large amount of trial parts that couldn't be used. This is why it took longer than a normal manual conversion as we needed to look into every part first.
Yes, this conversion isn't the cheapest one out there however it is something Beau wanted to spend his hard earned money on :) The labour cost of this conversion was the cheapest part of the job. The parts were the biggest cost factor. Which is another reason we decided to give out a parts list, so those wanting to tackle the conversion can start a parts corner in their garage!
Note: the parts we used/suggest may not be the only options, with more research/trial fits there might be other models that will also work.
We have to say a thank you to Beau as without him doing this conversion, we wouldn't have a list to share :)
  • Like 10
Today i got the following done
- took 350z seats out and gave them a good scrub.
- As the passenger side seat pressure sensor is hardwired on m35s, i installed a airbag plug for easy removal next time i have to remove the seats.
- Installed the brake cut mod at the auto gear lever so when in park it closes the pressure switch.
- I picked up a front drivers door to replace mine from someone running into it a while ago. Just needs a respray as the paint is not the best but atleast its straight
- I also sourced the orange interior panels and centre console to go with my 350z seats and to upgrade to the aircon vents being in the rear of the centre console for rear passengers. (You will see in the pic i got a rear boot roof panel not hacked to bits)
Tomorrow i will be installing the drivers door and replacing the top steering column cover due to old boost gauge install.
Edited by joshm35
  • Like 1
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
