Installled new head unit. Working well and much better sound.
What connector is that? it was connected in the old head unit
If that head unit is like mine should have wires in the loom labelled key1 / key 2. Tap into that connector red to key 1, green to key 2 and yellow to ground.
Speaking of which, in what was perfect timing my factory Bose unit died (at least the AC was stuck at 18°) . It'd been playing up for a few months, not playing nicely with the Grom USB2+. Luckily I'd already gathered the required replacement parts and had them sitting there ready. Cheap Chinese Android head unit with a PAC ROEM-NIS2 interface unit (because i'm lazy)
bolt on Dolphin intake pipe from JP
:rolleyes::rolleyes:
It's a shame that it doesn't fix the actual part of the intake that causes all the restriction.
Yes steering wheel control plug . Previous owner of my stag had it all working to a degree i replaced headunit and have since lost all controls
whether it is possible that the connector is somewhere else
Because I dont have buttons on steering wheel ;)
From memory the plug has about 6-7 cables running to it from the loom only 3 operate the steering wheel controls or are needed ? I could be wrong in saying this but most cars from base model to top of range have same looms and plugs in place it just a matter of weather they utilise them for that model
It's barely a restriction though. Think of those whale pen15 intakes on Hondas. It still only goes to the throttle body inlet size.. same goes with the turbo inlet... it's only gonna suck what it can spool... if that makes sense. It's more on the compression side that it really matters
Having a huge chunk of air sitting there ready to go will help improve response/spool.
  • Like 1
Good lucking pushing over 200kw without swapping the lower intake pipe. Where with an after market one you can push over 300 so I think it is rather restrictive
  • Like 1
You obviously haven't removed the suction pipe yet...
  • Like 3
Context is more along the lines of having a daily driven than chasing powaaah. Velocity stack on end of turbo ftw then.
Ps found the link to the 2009 post and no. Haven't removed that part yet.
http://www.sau.com.au/forums/topic/296472-fisher-mk2-suction-pipe/
Edited by Reaperblitz
So as some of you know last Thursday my car was stolen from my driveway, it was found on Friday morning crashed into a tree. I’m pretty gutted as I have put a lot of work into it. Here are some photos of the damage caused
Glass on my driveway
Rear Quarter Damage
Tailgate Damage
Broken Windows
Panel Damage
Broken Window
Cracked Windscreen
How they hotwired it
The same day that I came from the salvage yard, this was waiting for me at my desk. It’s the grill that I ordered from Japan in November
That is fkn terrible. Arseholes.
Nobody saw anything?
Presume it is a write off?
I asked neighbours, and my street there is normally someone outside, nobody saw anything.
It is getting assessed by the insurance company today, but i dare say it will be a write off
Edited by DrLui
I grieve for you.. buy it back and sell off the parts or put towards another stag?
If the insurance co operate, i do plan on buying it back, keeping what i want, selling what i dont, then buying another and starting again
  • Like 1
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
