C34 is 14mm. Not sure about M35. But you really you have at least a set of spanners if you own a car
Thanks for the info!
Yeah I really do need to get a set, haven't really needed any since I moved to Japan
went ahead and ordered a set from KTC
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.kpt.co.jp%2Fdetail_1.aspx%3FGId%3D14188%26MId%3D161%26FId%3D4%26SId%3D19%26TId%3D68%26FthId%3D194&edit-text=
installed bonnet damper kit today. it is for 350z but could be fitted on m35.
need to drill a hole on each side of fender due to m35 doesn't has it as stock (350z should have the hole as stock)
need 2 medium length bolts and nuts also.
open to stock height
happy with $60 delivery :rolleyes::rolleyes:
Looks like a handly little mod, interesting silicone hose layouts/ colour choice there mate!
that's BOV return hose. my bad i make wrong length when buy it... i re-ordered the customized one for 75cm long to make it beauty.
the hose is reinforced silicone hose, good for intercooler
Edited by YangLIU
Put some fresh front pads in yesterday, and chucked in some new plugs in at the same time.
Spent the first half of today chasing down vacuum leaks -.-
Still running like shit. Feel like I've done something daft somewhere/split something without realizing
Spent the last couple of weekends prototyping a rail delete kit. Covers bolt in place of the rails and have (printed) gaskets to keep the water out.
The covers don't look as good as a full patch job and respray obviously, but I like the fact that its reversible if I ever need to put the rails back on.
Cheers
  • Like 4
Link? Did you get my PM?
Cheers
That's a good job!
Hunting down a intermittent engine light issue. I have narrowed it down to something in the dash or the actual dash. Iv pulled everything out and cleaned jiggled wires. Just a question for those in the know, what is the black box with all the wires that is on the right hand side of the dash hole?
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
