my RS4s ECU decided to die on me the other day >_< mech said all the outputs are fried!!...
ended up finding a solution with a Series 2 Auto ECU he had laying around...
and now my car actually feels like its running better and smoother.. and no longer so rich... (it was running very rich lately)
trying to source another manual ECU at present via JDM..
is there any potential issues with running the auto ECU in my manual ?? Mech was very unsure if there would be ramifications.... :unsure:
If I can't find a reasonably priced manual ECU.. might just have to get myself a Vipec after I get my clutch done... *sigh* that time of the year I guess..
(thanks for the info Cam / Scotty)
yeah according to Mech the wiring was 'spaghetti'.. not sure what had been done previously in there, but its been sorted out apparently.... got a pretty hefty labour bill at the end of it though...
(and an empty tank for some reason :/ .. will have to question that one.. was 40km on the o.d.o since filling up)
and a $300 deposit on the auto ECU, (hence trying to find a manual one cheaper for the moment, then give it back)
Edited by atomaly
Tomas there is no problem or difference for running the auto ECU in manual. The auto has an additional function to cut timing when the gearbox says there is a shift taking place - but since there is no gearbox to send the signal that will never happen.
I ran an auto ECU in my manual for about 18 months until other mods meant I needed to go aftermarket.
Also, auto ecus will be everywhere....but manuals will be much rarer just like the donor cars
oh that's a relief :) .. I didn't modify my ECU, but then, I wouldn't know what's inside it.. I might go grab it now and open it up.. ... ok looks pretty stock.. no mods!
might just pick up a second hand auto ecu cheap, and give the other one back (as there is some issue with it which is why its his test one)!!
anyone got a spare S2 Auto ECU they'd like to part with ????? :D
I don't, but you should see them come up time to time, for about 1/10th what your tuner charged you. Make sure the part numbers match, there were smoe pinout/wiring differences in some of the models.
part number for mine is 23710 0V801 JECS TM
not sure what the Auto ECU number should be? does anyone have a list of which ones are compatible?
or at least how to tell which one is series 2.... did a quick search and can't seem to find much info.. (even looked through the stagea parts list thread)
Edited by atomaly
There are three different S1 ecus and thus three different looms. Earliest and most common is the OV300 followed by the OV301 and then the OV310
Series one are Hitachi Series 2 are Jecs. Some S2 ecus are OV810 and OV811
Grab this one really fast if its still available - fully tunable - worthwhile even on a stock motor!!! http://www.skylinesaustralia.com/forums/topic/407534-nistune-s2-rs4-neo/
I like what you're doin' there Leon.
Also, clear tube is for catch can?
Thanks Cam.
Yes, catch can under airbox. I just replaced the abomination of multi sized tubes that was my last effort. The clear will be decidedly brown in a few months, lol.
Thanks Cam.
Doesn't the clear tube to the catch can suck itself closed under idle vacuum? It gets pretty soft once the hose heats up
Not in this case because it isn't routed back to the plenum. After the catch can it goes into the intake before the turbo. At idle it is subject to atmospheric pressure only.
Just fitted Dale's Piano Brace. Awesome stuff.
Now just have to finish installing the wideband so I can put the dash back together.
I can't believe how long the 'piano' reference has hung around, lol.
Leon, do you have the PCV valve catch canned on the other rocker cover (assuming VQ25dets have the same PCV set up as VQ35des)?
Thats the one that would suck closed. I went and bought some heavy oil resistant pipe from pirtek for it. The one you have catch canned, and correctly I might add, required both vacuum and pressure. So it has to be able to suck in and blow out. I believe that the PCV is more important to catch can than the other side, because it has move vacuum drawing oily gas out and into the plenum. Thats how I thought it would work best anyway.
yeah, that's the one I have the catch can hooked up to - between the PCV & the plenum chamber just above the centre inlet runners
at idle it was sucking the hose closed so i ended up using some 3/8" brake booster hose which has enough reinforcement in it to stay open under vacuum
Yes & no. It is there but not hooked up. Everytime I connected the hose my old turbo would smoke because the seals were shot. It must have been adding pressure to the system. Maybe my PCV valve is stuffed, although it seemed to be doing it's job when I removed it to check. I have literally only just got my new turbo in (& now not leaking :) ) so I can connect the catch can again & see what happens. Hopefully my PCV doesn't allow boost into the engine & the pressure blows out something important...
Alex, I know you stuffed your can with steel wool. The theory is to filter the oil out of the air better, right? How long did it take to poke it in thru the drain hole?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
