I like your style. I want to fit an oil pressure/temp gauge somewhere, might try and move the DVD ROM, but I'm keeping the factory screen.
Picked the car up from AM Performance tonight. Andrew had pulled off the intake and traced the flange, so while he gets the flanges laser cut I get the car back so I can change the belts and do some other bits.
Was good to get it back and go for a proper drive, when I wasn't in as big a hurry as when I drove it there. Only the second time I'd driven it since the EVC6 went in.
Obviously there are still a few things to sort out with the EVC.
Firstly, I noticed the settings had zeroed out. I reset it all, and then noticed that every time the ignition is switched off it wipes the settings. I'll download the PowerWriter software too, and see if I can work out a decent solution.
Second, once setup for 15PSI peak/optimum boost, I notice it now makes 1PSI at ~1500rpm according to the EVC display. Boost feels like it comes on a lot stronger, and it feels much nicer to drive, especially higher in the rev range.
Thirdly, since I run a pod and the Turbosmart dual port blow off valve (plumbed back and adjusted properly), I've had some chirping and turbo noise which is apparently not a good thing. I spoke to Turbosmart and they blamed it on the pod, not the spring or anything else setup wise. I notice since the EVC went in this is virtually eliminated.
So all in all, very happy with the HKS EVC6, and once it's setup properly should be an awesome addition. Car certainly feels sluggish on the default 11PSI though!
I considered moving the DVD rom first up, but the cables to the back of it were so short, the only place you could really tuck it away is right where the passenger airbag sits. There's just no room under the dash without taking something else out & I wouldn't like the thought of cutting & extending the leads to somewhere else either, they look like they'd be pretty easy to screw up.
I want too concerned about losing the factory screen capabilities (mine was even converted to English when I got it) - mainly because I had already lined up the Alpine 2din
Your android tablet gauge pod is awesome.
Clean, no clutter, no tackyness... just smooth...
C34s wouldnt have a compliant OBD for that kind of multimonitor thingswoud they?
I had a look at a few ebay head up displays but wasnt certain if it would work and be configurable enough to give me:
A) RPM graph
B) dig speed
C) dig boost
Thats it, no other shit on my windscreen.
dig water temp would be nice.
Edited by shane344
A) RPM graph
B) dig speed
C) dig boost
The info is all interpreted through the OBD port by the HKS OB-Link, which is plugged into the car & sends the info to the android tablet (or phone) which is read & displayed by the corresponding app.
HKS have a list of compatible vehicles that the OB-Link works on, not sure if the C34 is on there or not...
The OB-Link cost me about $230 from Greenline
Took Moby for a drive, and filled up the tank.
Got the EVC setup. I really should learn to read instructions and push the combination to write the settings to the ROM.
It's now setup for normal boost at 15PSI and max boost at 15.5PSI. I don't want to go any higher than that on the stock turbo, lest it blow apart.
It feels brilliant from 1500rpm now, really pulls and goes, which makes the throttle restriction worse... Good thing it'll be leaving soon! :D
The turbo is making far fewer weird noises now, less 'helicopter' noises, less sneezing. It feels like it's either on, or off, with no slur in between.
I like it!
Found a standard 260RS front bar. It's months away from getting to me but i'll respraying the front end and touching up the rest of the car when it finaly get here.
Anyone keen on a genuine Freeway Dolphin front bar?
Pretty Sure its only the 35's that have this OBD2 port. 34's use the older OBD1.
Also did this to my stagea yesterday
drove over a roofing screw :verymad:
Edited by Nadnerb
Replaced the accessories and air con belts with new Gates Micro V belts according to Cam's helpful tutorial: http://m35stagea.info/forum/viewtopic.php?f=6&t=88&p=1867&hilit=belt#p1867
Used the same part numbers as Andy. Was pretty easy.
There is some squealing on startup now which goes away very quickly. I think the bracket for the tensioner on the aircon belt is cactus though, looks bent, so may need to replace this depending on how it goes.
Also thought it was interesting that Gates' instructions recommend replacing the tensioners with the belt - has anyone ever done this?
Also didn't bother putting the undertray back on. Looks pretty sad and sorry for itself. Think we need to look into getting something like this made locally:
Is this something AM Performance could knock up?
Possibly, otherwise I know dad used a local sheet metal mob to do some work on his rally car, might be worth chasing down.
For it to be worth making locally it'd need to be less than $200 each, since you can get them for ~US$170 plus shipping.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
