What stage pump are you going to be using? On our race car we run a 4 stage pump which scavenges two from the sump pan and then one from the back of the head. We are still using internal draining, though really the ideal would be to weld up all the oil returns and just let that one scavenge do the returning as that would avoid windage induced from oil draining right into the cranks vacuum trail. Has John considered doing something like that already?
Loving this build mate. Keep it up!
Interested in answer to this...
Here is a detailed Vid on how the merge of the wastegate pipe will be down. You need to listen to it with full volume and listen to what John has to say.
Always wondered about the advantages of something like that, following the direction of the turbine wheel/exhaust gas rotation.
The further this build goes the more impressed I am with the thought going into it.
Inducing swirl and/or taking advantage of it is very common in fluid dynamics and effective. Clever.
I am running a 4 stage pump, and yes the ideal way would be to weld the oil drains up , and we did not weld it however we have used bungs for all exept the ones on each ends of the head.
Ok,
The latest is the merge is getting cut up to form the shape that John had said on the Vid above i should be able to get some more pics on it tomorrow.
The next step is to install all the Motec system i have done some work in installing it, will get some pics up tomorrow. The other thing i am installing is the zeitronix E85 sensor to determine the concentration of Ethanol.
I should also get some pic of the bottom end as this has been completed.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
