Hey all,
Just an update on whats going on with my car, ive had a shitload of decision changes over the last few months but now its final and the car will be off the road for the next few weeks as of tuesday. Ive gone with the V8 engine. That being a Nissan Infinity Q45 car with a Vh45de, i pick the half cut up on monday. All the measurements were done at the wreckers and it will fit though some new headers will need to be made to clear the chasis rail but extractors where always going on neway so thats no problem.
The engine Standard Makes 280ps or 230kw's at the crank though many say this is under rated by nissan and it actually makes more. Ill be fabricating engine mounts at my dads factory as well as exaust manifolds, twin exaust system and then taking the car home to start on the wiring.
I will also be upgrading the breaks to 33 turbo items with custom made slotted and cross drilled rotors from DBA with my 4 stud pattern so i dont have to buy new rims, The car will remain auto with a stall convertor with the RPM to be discovered later as the car needs to be driven first to see where the best point for the auto to flare will occur. Only other costs other then steel will be a custom tail shaft and the diff is already a turbo item. The cluster will be changed to the infinity item and the nitrous will also be hooked up to this engine.
Ill try keep everyone updated and get a digital camera off a mate as mine decided to die and keep a picture diary as well. Aparently with extractors and some intake mods these engine make around 250kw's at the crank with bucket loads of torque and the best bit is no lag. Future plans for the engine will be a microtech system and blower for some serious fun. The best bit about the whole thing though is that the total cost of the transplant equates to less then the cost of a 25det half cut....
Cheers
John
https://www.sau.com.au/forums/topic/35764-time-for-na-power-the-wait-is-over/
  • Replies 390
Posted Images
Myself and my mechanic, have conducted heaps and heaps of research on a number of possible transplants and this one was the most unique so we went with it. The only possible drama's we can forsee is getting the auto computer to work with existing wiring in the car otherwise i will be changing everything which is not going to be fun.
Auto's are actually much better for drag racing, keeps times very consistant. Although yes i would prefer manual ill just see how it all goes first and recover from the current hole it has already burnt into my pocket.
not getting it too the ground will be the fun part!!
Picked up the half cut today and stuffed around as dad pulled out with letting me use his workshop though luckily my grandad said i could use his so i had to move it about and didnt really get a chance to do nething as i had to do stuff for uni tomorrow as well. Ill make a start tomorrow stripping the half cut and documenting where everything is meant to go and stuff.
Registration is simply a trip to the department of transport after its been engineered for them to sight the engine number. Insurance believe it or not is only 50 bucks extra a year through just cars.
I remember there is an equation based on the weight of the car to what size motor you can fit. Or something like that anyhow.
Hence in the R32 GTS-T you can fit a 2.6litre turbo. 2.6 is the largest legal turbo engine you are allowed to fit.
From memory in NA it was a 3.5ltr or 4.5ltr I can't remember?!?!?
Should be nice though.. Spin a few people out. :)
hey mate the rules in QLD are slightly different, its something like largest NA is something stupid like 6 ltr's and largest forced inducted is a little under 4.5, but what is engineered and mod plated is legal isnt it :) although it wont be force inducted for a while.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
