FInally able to see the dyno plots on a big screen! LOL.
As a true blue GT3076 RB25 fan, much thanks to my old pal Lith :action-smiley-069: , i am hugely impressed about how much this thing monsters a standard "laggy"GT in spool! I always thought my GT30 spooled relatively quickly too.
Cant wait for some high quality clips inside and out of you lifting the tarmac on the open road haha.
Have you ever considered a plumb back gate? Or does the external give you a too much of a damp patch? :D
He's got an interchangeable setup, can switch it between plumb back and atmo at will. Really is the perfect setup. Congrats Mat :)
Correct, and thanks man!
amazing result man for a stock motor too!
makes you think why people spent thousands on built motors to only make 300kW, when clearly a stock NEO is making nearly 400kW
Exactly what we discussed on the weekend! If the NEO ever has any issues ill get another one, rinse and repeat!
  • Like 1
What a nugget. :)
jks - well done mate. Looking forward to some thrashing with you.
Lolz, get back to ya Evo forums ya kent ;)
Hurry up and get that motor built so we can cruise!
  • Like 1
Get a gopro and a head strap and go for a cruise so we can strap in and feel the G's!
Haha yeah we have a Gp Pro but unfortunately the car will get locked up as i have to go to VIC for a week, when i return ill be doing some suspension work and prepping for some texi fun and THEN hopefully get it on a track and show just how hard it really goes compared to the GT3037, the old turbo has nothing on the new ANYWHERE in the rev range, to have a car more responsive yet with more power was just a WIN!
I dont have any decent pics yet of the engine bay as its still only half done and filthy due to lack of time -
After all the hype with the power figure etc, it WILL take me a while to get up videos and results properly as i have to go interstate and the car will be locked away safely... Once i get back ill crack it onto high boost and E70 and get some footage and proper stats! Also by then i should have all the Dyno sheets to post up from the various boost levels as well as various fuels.
For now, another addition is the wiring of the gauges -
You mean you lower the boost? Sounds ghey... :P
Lol, i am trying to get up to high boost ya mongrel :P I picked it up on E46 fuel so am working to get it above to E60........
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
