hahahaha still laughing about it, such a good day
Wouldnt have happened if he had the lifejacket on! You couldnt have got your head close enough to the engine bay with that stupid thing on :P
I know why it couldnt be fixed, you were to busy pulling some idiots black 32 out of the sand :whistling:
Lololol well yes you did manage to take up some precious time :P jks
I agree, hard pipes are a better idea but welding a bend to the turbo makes it almost impossible to sell. Straight joiners on a cast alloy 90 may be a little better but it will limit your power as the internal diameter is much smaller.
I was running 40psi through mine, 2 inches from the maifold. Perhaps yours is just too close, can you spin the housing a little?
There are some great heat insulating and heat reflection products out there these days, no need to change the setup imo.
I run a 45deg silicon bend exactly the same as yours, on the track punishing it for 20 mins at a time running 21psi it was fine. Has held up to two of those track days now. But as scotty said, mine sits probably 4-5 inches from exhaust manifold and has zero issues.
I dont think resale is an issue as i am so happy with the results and performance i dare so i wont feel the need to change :)
Ill try the alloy elbow off the housing as i dont want to restrict any performance!
Good point about rotating the housing, that is something i hadnt thought of and will have a look, could be possible even if its just a bit...
Yep so i think mine is too close to the mani for one as i can only just get my hand between it.
Ill just get it welded up and do it right this time i think! I need to eliminate any potential problems!
So the car has its new home and i will try get my tools and stuff across there on the weekend! I think the shed will need its own build thread so i can come up with some designs... At this stage i am working on something like this -
Then maybe i should coat this white and do the white writing on the tyres? :rofl:
Nice S chasis! does it chirp 2nd!
also in response to mr liths comments a few pages back.. do a 1:06 with smoke and skids JOB DONE!
It wheelstands 4th if that helps :P I think i need to do some adjustments on the foot pedal lolz
And agreed with the comments above, working on it ;)
  • 4 weeks later...
So, no real updates here... Moving house took a lot longer than expected and since doing that we have had no internet and no phone service hence we have been in the stone age!
I have started working on the shed as planned and its coming together as per my rough floor plan -
Also, The LOWDOWN.com guys now have the pics online from the JEM shoot, check out the workshop feature if you get a chance -
As some of you know the car is back at its second home.... JEM....This visit is just to fix a few weak spots we found at the track day....
Hopefully when it returns to the road it will also be quite capable on the track, 2014 will be more focussed on track days and hopefully will get some good laps in without issues!
This photo is thanks to Mr Paul Kelly :D -
735811_10152027364398329_717840852_o_zps
It looks like shit as its been towed in the rain twice since the track day :/ some serious TLC needed once it comes home!
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
