hahahaha still laughing about it, such a good day
Wouldnt have happened if he had the lifejacket on! You couldnt have got your head close enough to the engine bay with that stupid thing on :P
I know why it couldnt be fixed, you were to busy pulling some idiots black 32 out of the sand :whistling:
Lololol well yes you did manage to take up some precious time :P jks
I agree, hard pipes are a better idea but welding a bend to the turbo makes it almost impossible to sell. Straight joiners on a cast alloy 90 may be a little better but it will limit your power as the internal diameter is much smaller.
I was running 40psi through mine, 2 inches from the maifold. Perhaps yours is just too close, can you spin the housing a little?
There are some great heat insulating and heat reflection products out there these days, no need to change the setup imo.
I run a 45deg silicon bend exactly the same as yours, on the track punishing it for 20 mins at a time running 21psi it was fine. Has held up to two of those track days now. But as scotty said, mine sits probably 4-5 inches from exhaust manifold and has zero issues.
I dont think resale is an issue as i am so happy with the results and performance i dare so i wont feel the need to change :)
Ill try the alloy elbow off the housing as i dont want to restrict any performance!
Good point about rotating the housing, that is something i hadnt thought of and will have a look, could be possible even if its just a bit...
Yep so i think mine is too close to the mani for one as i can only just get my hand between it.
Ill just get it welded up and do it right this time i think! I need to eliminate any potential problems!
So the car has its new home and i will try get my tools and stuff across there on the weekend! I think the shed will need its own build thread so i can come up with some designs... At this stage i am working on something like this -
Then maybe i should coat this white and do the white writing on the tyres? :rofl:
Nice S chasis! does it chirp 2nd!
also in response to mr liths comments a few pages back.. do a 1:06 with smoke and skids JOB DONE!
It wheelstands 4th if that helps :P I think i need to do some adjustments on the foot pedal lolz
And agreed with the comments above, working on it ;)
  • 4 weeks later...
So, no real updates here... Moving house took a lot longer than expected and since doing that we have had no internet and no phone service hence we have been in the stone age!
I have started working on the shed as planned and its coming together as per my rough floor plan -
Also, The LOWDOWN.com guys now have the pics online from the JEM shoot, check out the workshop feature if you get a chance -
As some of you know the car is back at its second home.... JEM....This visit is just to fix a few weak spots we found at the track day....
Hopefully when it returns to the road it will also be quite capable on the track, 2014 will be more focussed on track days and hopefully will get some good laps in without issues!
This photo is thanks to Mr Paul Kelly :D -
735811_10152027364398329_717840852_o_zps
It looks like shit as its been towed in the rain twice since the track day :/ some serious TLC needed once it comes home!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
