Matty I finally did my power steering cooler after one year of talking about it haha..
I used red gates hose because it's half the price of black gates hose and the core is from a R33 auto transmission cooler
Nice work! Let me know how it goes :yes:
So, as planned i took the car to Ringwood for the practice day, i turned up and the only other guys there were in a formula ford and a spastic kart... They were not there for long and basically i had the track to myself for the day...
First run out was sketchy az... The car nearly understeered off the track at low speed which was not cool! I checked the pressures and they were miles too high, i let about 10psi out of the tyres and ran again...
The pressures helped heaps!
So i ran lap after lap after lap... I tried to work out how many roughly i had done at the end of the day and i estimated 60 runs in my car and 10 in the GTI :woot: There was nothing wrong with my car, just let it cool down after a long session of runs...
The GTI was quite quick considering it is 100% stock and on average tyres... It ran a high 36 compared to my car which was mid 34's :yes:
There was no official timing for this day so we were relying on stopwatch times which were not very accurate...
I have vids to come, ill post as soon as i get a chance.
There are a few videos to upload but i have the slowest farken internet connection on the planet so they will be coming slowly :wacko:
The tyres by this stage of the day were rooted! The rear end was all over the place and although it provided a few laughs i decided to call it a day after basically sliding the whole track lol
Needs more gaaaate while sideways. You should be able to link that whole track ;P
Neat little track. Is that the same place you've done hill climbs at?
These are some of the runs in Carmens car... The tyres went off real quick but we didn't alter the pressures as we were just trialling it for fun :yes:
We went for times after this footage and even with the tyres not doing much it was still clocking high 36's
Lol i was trying to keep the thing straight :P
Yeah that is Ringwood's hillclimb track! If you look in the footage you will notice the new section of track, as soon as that is CAMS approved it will enable them to have something like 4 track configurations which will be epic... Also, this is the track with the race track being built next door! So it is awesome especially being 5-10mins from home!
Mint videos Matt, however i agree with Tim. Needs more skids and gaaaatttteee
Lol skids were just a byproduct of poor tyres and poor driving at the end of the day :laugh:
  • 3 weeks later...
GTI needs exhaust, intake and tune for more powerz.
Lol says Mr Mario Kart over here!!! I have video proof that you need more powerz :P
  • Like 1
Now updates... I have been busy sorting shit out and as usual updates have been slack!
Firstly, Tow car... New oils, filters, suspension bushes and the 3inch exhaust has now been fitted back on with the biggest muffler on the planet to keep the tree huggers happy! It now has its grunt back so ill stop complaining when towing :laugh:
It now sounds quite tough without being obnoxious...
As for the skyline, it has also been copping some attention... It spent a week with Road2Race and it turns out it had some SERIOUS alignment issues... When the owner of the shop sends you a message simply saying W..T..F.. you know there is something not quite right lol
So for the past few months on track etc i have been trying to drive with massive toe in, bugger all camber and some odd ride heights... I just thought it was a hard car to drive but turns out the previous aligner was a retard! Anyway, instead of just another basic alignment i had all the suspension reset, regreased, heights set and a full cornerweight and alignment... It now sits as good as it can on the current suspension setup -
The alignment is aggressive compared to what i am used too but is just the starting point, with some tyre data and feedback we will further develop these settings to better suit my needs. The car still weighs factory weight will all the changes i made which is dissapointing to know its such a heavy nugget haha
I wouldn't bother with the temps at the hillclimb. You're not going to get them warm enough to gather decent data, and by the time you make it back to the staging area, they are going to be cooled of any heat you did make. Did he show you how to take temps?
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
